F5 Turbo Builders Thread
Joined 2009
I was listening to some vinyl last night through the cascoded V2 when my daughter happened to walk in; she sat down for a listen and said "it has such deph" followed a short while later by "its like being there!"
I could'nt agree more I think its a keeper.I'm listening with P3 in mid position;once I'm used to the amp I will have to experiment.
I think I asked once before would there be any benefit to using four output's and lowering the bias? Its currently running at 320mv with the sinks a cosy 45C.
Joined 2009
A couple of pics.
The power supply before I wired in the umbilical.
The amp on top of p/s.
Yes. I think there is another advantage that I am unsure of. One reason Nelson used the diodes was to reduce drop across Rs and increase the available current from the fets. By using more fets, you get more current capability by default and each fet has to contribute less to the total demand. This is speculation, but i wonder. Other benefits are higher DF and lower temps inside the individual fets, making it easier to maintain a specific temp.
Joined 2009
Thanks Buzz I think I'll run it as is for a while and maybe double up some time later in the year.I must say I'm liking what I hear this amp is so in control;not that the standard F5 was'nt; but the V2 is just so authoratative and I'm sure Im hearing stuff that I was'nt previously.
I am busy this weekend, but will be playing with different numbers of outputs next week. If you wait, I will post about my experience. Here the picture of my amp(I really like this concept of chassis:)
PKI - (1) what value caps are you using?
(2) what voltages are you running on the secondaries?
BTW I like your layout, it makes it very simple and clean to transplant to the case eventually.
Joined 2009
Don't have to convince me. Dual mono helps out as well in terms of low end, clarity, and blacker background. Best thing in the world is to just stop and enjoy.
Thats exactly what I intend to do.I've hardly turned the amp off the past couple of days.
A big thanks to Nelson;Teabag for the pcb's and yourself for the matched Fairchilds and cascoding transistors. :cheers:
PKI
Joined 2011
well. that only helps the main fuse and the transformer. but it does nothing with the charging current to the caps. and that is hard for the transformer.
AndrewT may have a recipe for this one.
I am not so sure about this, but I am not an engineer, so maybe some parts in the picture I have in my head will cancel out and everything will be as you say :)
