F5 Turbo Builders Thread
Old 2nd January 2013, 01:52 PM   #771
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Folks:
While I understand that it would be better to cool the heatsinks themselves instead of focusing on managing the temperature inside of the chassis, I trust that forced air convection inside of the chassis would still benefit an F5T V3. I've been thinking about mounting an 80mm super quiet pc fan to the rear panel of one of the HiFi2000 5U enclosures that diyaudio's store is selling. Is there a reason why this would not be a wise choice?
Scott
Good decisions are derived from experience; experience is derived from bad decisions (unknown)
also, "Everyone has a plan, till they get punched in the mouth" (Mike Tyson)
Old 2nd January 2013, 03:11 PM   #772
AudioSan is offline AudioSan  Norway
Originally Posted by SRMcGee View Post
Folks:
Scott
it can not hurt it easier on transformer and caps. but it will not help the fets much.
Old 2nd January 2013, 03:13 PM   #773
Blink_PT is offline Blink_PT  Portugal
Blink_PT's Avatar
Folks:
Scott
Can cause an airflow throughout the interior, the rear one meter the air out, a fan lid on the input (on the inside). Or the base on the outside (not seen), if the base with holes (air intake).
For example the fans of SilenX (IXP-64-14 with 92mm) have 14db and 42 CFM, practically no hear.
Use on my PC and dropped his temps + - 20 degrees.
Old 2nd January 2013, 03:17 PM   #774
in a PC, all that creates heat is INSIDE the chassis. so thats a whole other ball game. if you had a heatsink outside the PC chassis with all hot part mounted, you would not get much help from a fan in the chassis.
Old 2nd January 2013, 05:29 PM   #775
Blink_PT's Avatar
Correct, but I have done experiments with fan and without fan dento F5 and temps are going fall, that's a fact.
Of course the ideal would be cool sinks, but it is complicated, so we can try to cool the heat that causes this, the mosfets, so an air stream always gives a helping hand.
I am thinking of putting aluminum feet fixed in heatsinks, then F5T I'm building will land on a 10mm aluminum plate that will be cooled by two or three fans, almost as gadjets to cool portable pcs...
Old 4th January 2013, 04:11 PM   #776
well. no i have all the parts in house. exept 2 bloody resistors i forgot the 47.5Kohm input resistors. o well. i found some 47Kohm in my bind not dale, but heck but have not heard anything from variac regarding testing of the boards. and i think i'm getting the sinks cut tomorrow, so i'll just have to use the prototype boards that i have. regardles of the tiny foults. to night there will be some soldering.
one question for buzzforb. have you tried different cascode voltages?
i'm wondering if i chould go for 16.4V or 20.6V.
Old 4th January 2013, 05:44 PM   #777
god damn. where the heck is my J-fets? it seams they went in the trash. grr. good thing i have plenty more
Old 4th January 2013, 06:27 PM   #778
one board down. 9 to go
Old 4th January 2013, 08:22 PM   #779
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I played around with it some. I am not going to claim to know for sure, but I would think you have to be careful and make sure you don't run out of headroom, causing FE to clip. Half supply is fine, all the way up to standard Jfets dissipation ratings.
...Shape the sound , Man!
Old 4th January 2013, 09:02 PM   #780
thats what i was thinking too. so i went for 16.4V
one channel is finnished now. well, exept output fets and diodes.
just hoping i get the sinks cut tomorrow
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
