F5 Turbo Builders Thread
Old 1st January 2013, 04:18 PM   #761
AudioSan is offline AudioSan  Norway
Lo_Tse. for 100W class A at 8ohm, you need around 45V rails and 2.5A bias.
with higher rail voltage and same bias, the amp will go into class A/B above 100W.
Old 1st January 2013, 04:20 PM   #762
Originally Posted by anilva View Post
I mentioned that it is 47V DC at no load earlier. Looks like I have to use a quite cooling fan mounted to the top cover to evacuate hot air from inside and also provide enough ventilation to the bottom cover to enable air flow.
mount some fans under the sinks that blows air up. it's not the heat inside the chassis that is critical. it's the sink temp.
Old 1st January 2013, 05:22 PM   #763
anilva is offline anilva  India
Backed off my bias to 225mV levels and now the amp is stable with it's bias and temperature. Also did some listening tests. The V3 is terrific. Absolutely quite and no noise or hum. Sounds wonderful with very tight hold on music and bass. Little more warmer than original F5.
For my setup at the moment, I am Ok with what it is delivering. I may add a fan little later to drive up the bias. For the moment, I will enjoy the amp.
Thanks for all the help.
Cheers.
DIY F5T, F6, Aleph J, M2 & 45/2A3 DHT SET Amp, Fostex 206 based BLH, Altec 515 LF & 288 HF Onkens, Tannoy HPD Speakers. EMT950, Technics SP10, Garrard 401, TD124 turntables.
Old 1st January 2013, 05:51 PM   #764
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Warmer was first noticeable difference compared to F5. Perhaps saying it has more body is more appropriate, dunno. Glad it turned out well.
...Shape the sound , Man!
Old 1st January 2013, 05:53 PM   #765
you MAY want to try 1.5ohm source resistors for a total of 0.75ohm with that low bias pr device. then you can take advantage og the diodes. with 0.75ohm source resistance and 0.45A bias(drop of 225mV over 0.5ohm) pr device you get 337mV drop over source resistors.
or just use 2 output pairs. and 0.8-0.9A bias pr device.
Old 1st January 2013, 06:22 PM   #766
dazed2 is offline dazed2  Canada
Anilva, what is the depth of your case, and what is the height of your heatsinks?
They seem a little small for V3....
Old 1st January 2013, 07:10 PM   #767
Lo_Tse is offline Lo_Tse  Canada
Audiosan
Thanks! I get a little condused here. In the original F5, each device was biased at ~1.3 A and the rail voltage was set at 23V. NP mentioned that with these parameters, the dissipation per device was kept at ~30 watts, about 50% of its max rating.
Going to the V1, the rail voltage goes upto 32V, NP dropped the bias to ~ 1A, in order to operate within the 30 watts per devices target. If for the V3, with a rail voltage getting up to 45 V, the bias should decrease further, right (or am I missing something here)? Is the 2.5 A the current bias set for each output device?
I am not trying to be nitpicking here. I understand that one can change the rail voltage and/or bias around as see fit. I just would like get a better understanding of what are the "optimum" parameters for this V3 amp. This will be the starting point of any changes/experimentation.
I have sourced a bunch of big caps for the PSU but these are rated at 50V only (I assumes the rail voltage for the V3 is teh same as V2). With a rail voltage at 45V, it is getting a little too close for comfort.
Old 1st January 2013, 07:22 PM   #768
the 1A bias is pr device. but that is a litle maximum with 0.5ohm source resistance do to the diodes starts conducting around that level. maybe even before. and then you got a runaway problem.
the 2.5A bias is total for all output pairs.
for the v3 you must have minimum 45V rails to get to the 100W mark. with 32V rails you only get 50W at 8ohm. even with 10A bias.
Old 1st January 2013, 09:15 PM   #769
Thanks again for the clarification.
Old 2nd January 2013, 02:21 AM   #770
rolandong is offline rolandong  Philippines
Suggest to reposition FET placement to heatsink center to maximize heat spread. Consider split output boards like one posted by Variac which will be available soon in diy store, this provide flexibility to maximize your already massive heatsink.
Pinoy ikaw ay pinoy... ipakita sa mundo... kung ano ang kaya mo...
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
