F5 Turbo Builders Thread
Old 10th December 2012, 08:48 PM   #641
AudioSan is offline AudioSan  Norway
buzz. i'm gonna have 0.6A bias pr fet. and wondering if the best way is to use external sinks or main sinks for the diodes. the main sinks will run pretty hot i guess. 125+W pr side on 2x 10.080" profiles, 6" long.
on the other hand. with external sinks. how will the transaction be, when you WANT the diodes to conduct. i'm way out of the 1A ranch. maybe connect the diode sink with the main sinks with 2 L profiles?
i can not crank up the bias with rail voltage of +/-50V
Old 11th December 2012, 08:24 AM   #642
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
I sent the payment on the 7th of Dec, the day I posted here that I finally ordered. It's in the board fab and Fed- Ex's hands now. I promise to get them in the store ASAP when they arrive.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 11th December 2012, 09:11 AM   #643
Marra is offline Marra  United Kingdom
What would be a suitable alternative for the 2SA1837 and 2SC4793.They don't seem to be available from Farnell or RS and the only supplier I've found are asking close to a fiver each.
Old 11th December 2012, 09:14 AM   #644
R.I.P.
does rapid or dalbani stock them?
regards Andrew T.
Old 11th December 2012, 10:13 AM   #645
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Marra,
I'll send you some with your diodes.
...Shape the sound , Man!
Old 11th December 2012, 03:33 PM   #646
Andrew I did'nt check those two.I tend to deal mainly with Farnell.
Buzz you are a gent thank you.
Old 11th December 2012, 03:57 PM   #647
BigE is offline BigE  Canada
BigE's Avatar
Sanity check time for me....
V3, 4 pairs per channel, biased to 3,0 amps per polarity, 50 volt rails. That gives 0,75 watts/FET, or 0,35 Volts. Total bias current is 6 amps.
Now total dissipation is 8 * 50 * 0.75 = 300 watts. That can easily be spread over 4 regular sized F5 heatsinks at 75 watts per heat sink -- each heatsink carries one pair of FETS.
Efficiency is around 33% at full class A power. Does that sound about right?
As for Transformer VA, clearly 300 VA is needed just to run the bias. Now, add the load requirements. P=150 rms = 300 peak.
So, P=IV , V = 50 says I = 6 amps peak. That is another 300 VA to power class A operation. (That checks with doubling the bias current to come out of class A).
So far, the transformer has to be 600 VA *bare minimum*.
What do you spec for Class A/B overhead? Do you limit the VA to provide 50% of the steady state operating current of the output transistors?
Also, how do the diodes impact the heatsink size?
Old 11th December 2012, 03:58 PM   #648
6L6 is offline 6L6  United States
6L6's Avatar
Gentlemen,
I am helping a forum member with his F5T -- I will save you the details and ask;
Would there be any problem building a v3 with ~ 42v rails and only 2 pair of output transistors?
Thank you,
-Jim
Old 11th December 2012, 04:05 PM   #649
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
there is no point making current hungry load oriented solution , without full current capability
catch is - what's limiting factor , responsible to just two pairs choice ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 11th December 2012, 04:11 PM   #650
6L6's Avatar
The reason for the high voltage rails is due to a mistake when ordering the transformer. So am trying to see if there is a good solution to using the parts on hand.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
