#621 | |
how will the pads be? same as other store boards?
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#622 |
diyAudio Editor
The mounting is made to work with the UMS. If you remember in each kit there is a gainstage board for 2 ch that can be snapped in half, and 2 N ch boards, each with 2 MOSFETS and 2 diodes and 2 P ch boards each with 2 MOSFETS and 2 diodes.
-One kit spreads things out well for 2 ch (each with a P and an N output bd so 4 output MOSFETS per channel, 8 total) in the 5U x 400 chassis. -One kit can use half the gain bd. and just one N board on one side and one P on the other in a 4U x 300 chassis as a monoblock. So one kit gives 2 smaller monoblocks each with 4 MOSFETS -Two kits could make 2 monoblock 5U x 400 chassis' each with 2 P and 2 N output bds so 8 output MOSFETS per channel, total of 16 MOSFETS in two 5U x 400 chassis. As far as diameter of pads on traces, well whatever Alex did...
2013 Burning Amp Festival announced: Sunday, October 6th in S.F. We need Volunteers & sign-up's for what you're bringing! Last edited by Variac; 8th December 2012 at 04:14 AM. |
#623 |
Cool Variac! Can't wait !
I know someone here probably asked already, but is it relatively easy to convert it to a balanced system by crossing a few grounds? |
#624 | |
#625 | |
but that is all it is yet. and it will be a heck of a powerplant. 4 pair input J-fets. 16 pairs of outputs. and +/- 55-60V and you got a 300W class A amp ![]() ![]() acctualy. you can rach the 500W class A mark at 8ohm
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers Last edited by AudioSan; 8th December 2012 at 06:04 AM. |
#626 | |
yep and my very own block heater for those cold winter nights
#627 |
Balanced is best wayy to get votage up without raising rails, taking advantage of available current.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#628 |
I bet it is not as quite as your 4 Pr standard version .....
#629 | |
and have current from hell and above. same with outputs. and maybe input J-fets
#630 |
ok ok, I was just daydreaming about a balanced version.... have no real aspirations for it anymore.
![]() Standard 4pr version it is, I think its enough power already and plenty quiet if it mimics the regular F5.AudioSan, what are your source resistor values? With the rails that you have, if you run 3A bias you should be able to get close to 150W. If you use 0r47 then overall, V=IR your total bias voltage should be 1.41V right? Then each FET should run at only 0.35V bias. Last edited by dazed2; 10th December 2012 at 06:20 PM. |
| F5 Turbo Circuit Boards | chchyong89 | Pass Labs | 2120 | Yesterday 09:50 AM |
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| B1 builders thread | Bas Horneman | Pass Labs | 688 | 27th February 2013 11:15 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
