F5 Turbo Builders Thread
Old 5th December 2012, 03:57 PM   #611
AudioSan is offline AudioSan  Norway
Originally Posted by BigE View Post
Are the sinks from heatsink USA more appropriate? You can order them as tall as you like.
yes. sort of. they have more spacing between the fins but they come only in raw aluminium
Old 5th December 2012, 05:18 PM   #612
dazed2 is offline dazed2  Canada
yeah but the difference is that Antek can also custom build a case for you with their heatsinks integrated to it.
Old 5th December 2012, 05:20 PM   #613
but most of the sinks are made for forced cooling thats why the spacing between the fins are so smal.
Old 6th December 2012, 05:54 PM   #614
BigE is offline BigE  Canada
BigE's Avatar
I think this is correct now. Comments?
Prms is the Watts RMS output.
I^2 = Prms/8R0
Irms = Sqrt(I^2)
Vrms = Irms * 8
Vpk = Vrms * 1.414
Vrect = Vpk + 5.6 V
Vac = 1.3 * Vrect
Loss/droop of 5.6 volts. This is Class A.
Prms I^2 Irms Vrms Vpk Vrect Vac
20 2.5 1.581 12.649 17.885 23.486 18.066
50 6.25 2.5 20 28.28 33.88 26.062
100 12.5 3.535 28.284 39.993 45.593 35.072
150 18.75 4.330 34.641 48.98 54.582 41.986
As far as the VA for each transformer, that is a different story.
Please note, I take no responsibility that these will work in your amp, as I'm just trying to learn this stuff and could be very wrong.
AudioSan,
The table suggests you are going to get 135 Watts from a 40 V transformer. In real life, a little less.
The table also suggests that 50 V caps should be OK for a 100watt amp.
Old 7th December 2012, 04:00 PM   #615
BigE's Avatar
Who do I speak to about getting my login name changed to "Threadkiller"?
Old 7th December 2012, 04:44 PM   #616
flg is offline flg  United States
flg's Avatar
Personally, I think your first equation is Irms^2= Prms/8R0,
But this is backwards???
SqRt (Irms^2) *1.414=Ipk
Ipk*8R0=Vpk
Vpk+(2V MOSFET Drop)= powersupply DC
DC/1.3=Secondary Vrms
You could experience MOSFET drop closer to 4V but it depends on your VAS drive and or other factors.
Depending on the load and the rectifier Vf I ussually see about 2.5V drop from the unloaded condition. YMMV
I ussually use schottky rectumfriers with about .3-.4Vf @ load.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 7th December 2012, 09:02 PM   #617
buzzforb is offline buzzforb  United States
buzzforb's Avatar
I am thinking with 32V rails, you are real close to 100W unless you have an undersized trafo and overly large smoothing resistors in the PSU
...Shape the sound , Man!
Old 7th December 2012, 09:38 PM   #618
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Heatsinks over about 6" tall have diminishing returns. I wouldn't bother going over 8" tall. I think its because the lower part of the sink heats the air traveling up the slots to the point that the upper part of the sink doesn't cool much.
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 7th December 2012, 09:40 PM   #619
diyAudio Editor
Variac's Avatar
The PCB's are ordered and should be in the store within the month. We got expedited shipping and production.
I know this has been an incredibly long time, but we don't have full time people helping here at the forum or at the store and I have been swamped with work at my "real Job" Also, there were issues with getting the order right with the maker, which is really important !
Old 7th December 2012, 10:14 PM   #620
BigE's Avatar
Ipk*8R0=Vpk
It does not really matter when you do the calculation for Vpk, just so that you do it somewhere.
My guestimate for 5.6 needs some looking at.
A great read, from page 64 and on.
http://www.onsemi.com/pub/Collateral/HB206-D.PDF
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
