F5 Turbo Builders Thread
Old 27th February 2012, 09:47 PM   #51
Bksabath is offline Bksabath  United Kingdom
Banned
Originally Posted by CanAm Man View Post
Well, heck, yeah!!!! Since we to "direct couple" the stages of our audio systems, why not "direct couple" our power rail requirements directly to our (local) power mains. Just think--eliminate the cost and weight of the toroid....
Hhhhmmmm--wondering about the safety considerations.....
That be quite right especialy on your side of the pond you have 110 v mains
In the UK we have 240 V bit higher than rest of Europe but still inthe 6% limit that regulations alowd.
Good thing we have loads of cheap traffos as power tools in industry must be suplied by those transformers at 110 V and 3 KVA are preaty cheap
Safety is big concern I understand but one would take precautions about that any way (EG bleaders on the capacitors).
Be nice to split your 110 to 2 55 V single diode rectifier instead of bridge?
Plenty of V drop avvaliable for CRCRC or Cokes.
If I know samebody that can pull that it is you....
Old 27th February 2012, 10:08 PM   #52
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by BigE View Post
Can the F5 turbo V3 run with 112v rails ? less.
112v rails require output devices of 225V, minimum.
Old 27th February 2012, 10:41 PM   #53
CanAm Man is offline CanAm Man  United States
Thanks, Bksabath--but you are SERIOUSLY overestimating my talents!
Besides, I don't think I'd want to be the "first kid on the block" to tie power mains (one way or another) into a set of speakers (unless, of course, I borrowed those speakers from a neighbor I didn't like too much....!)
I think I stick with toroids and other heavy transformers....
Old 27th February 2012, 10:52 PM   #54
a.wayne is offline a.wayne  United States
Sin Bin
Dutchie ... Good show .... I hope your book nuh only have 2 pages ........
Old 28th February 2012, 01:16 AM   #55
Banned
Maybe this need to be duble ceck. Does' not Papa amp work on 70 V rails
mean + 70 and -70 V 140 V total
If one split mains 110 V to 2 X 55 rails dc be around 77 V Rails
Old 28th February 2012, 01:56 AM   #56
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
indeed!
Directly connecting the rails to the power mains (ie without a transformer) is SOOOOOOO darned dangerous that we don't even allow discussion of schemes to do it. Per Rule 3 & Note 2. The issue of why its so dangerous has been explained in various threads though....
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 28th February 2012, 04:55 AM   #57
Banned
Sorry not intended to suggest anitink dangerous.
Just to recap and put this to rest can you post links to the treads
Old 28th February 2012, 02:52 PM   #58
BigE is offline BigE  Canada
BigE's Avatar
My bad.... 60 volts -> about 84 (60*1.4) the other way is 84*0.7. I mixed up the numbers and went 60 * 1.7..... I need a vacation.
So, would 85 to 90 volt rails work out ok?
Old 28th February 2012, 02:54 PM   #59
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
BIGE. does it have 240v taps, so you could run half that?
Salas Boards 2018#1 On Order | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards, PS and transformers Available PM | Sony VFET CSX2 AL boards In Stock
Old 28th February 2012, 03:35 PM   #60
BigE's Avatar
Yes, I can wire it to run at various voltages...it has 5 outputs, 60/0/60 each, each carrying 4 amps max for a total of 20 amps * 120 volts = 2400 VA.
Here are the specs: http://shop.plitron.com/specs/901600.pdf
My house wiring is a bit hot, so I currently run the orange/brown pair (125 volts) and get 57.5/0/57.5 balanced power.
I could run two 100 volt primaries in series for 200 volts. The voltage is normally a bit more than 122 at the wall. That should give me 122/200 * 60 = 0.61*60 => 36/0/36 on the secondaries.
That would mean 36*1.4 or 50 volt rails.
How much power could this reliably make?
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
