F5 Turbo Builders Thread - Page 59 - diyAudio
Old 3rd December 2012, 04:59 PM   #581
no.
using a 35Vac transformer you will likely get ~50Vdc to 51Vdc across the smoothing caps when mains voltage is nominally the same as the transformer rated voltage. Use 63V capacitors, not 50V.
The supply voltage will droop when you bias the amplifier.
Expect the droop to be about 2Vdc when passing 1A of bias and 3 to 4 volts when passing 2A of bias. For 100W into 8r0 the bias will need to be almost 2.6A and the likely supply droop will be around 4 to 5volts.
That will bring your rail voltage down into the range 46Vdc to 48Vdc.
This should be just about enough to ensure you get 40Vpk into your 8r0 dummy load.
Now your output stage is dissipating ~244W (94V * 2.6A) and will need big heatsinks.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 3rd December 2012, 05:47 PM   #582
a.wayne is offline a.wayne  United States
Sin Bin
He should use 30 volt transformer, this way he can still use 50v caps ....
Old 3rd December 2012, 06:09 PM   #583
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by a.wayne View Post
He should use 30 volt transformer...
I guess that would still be enough for F5 amp
I still remember the times when 33V trafo was 'big', and close to the classAB 'safe limit' with any DIY amp
and now in classA...DIY certainly have changed
Old 3rd December 2012, 06:31 PM   #584
buzzforb's Avatar
Buy the spec'd 24V secondary trafo that Nelson recommends in the article. It will yield correct rail voltage(appx 32v) to take advantage of current avialable from output, set according to the article. Venture outside these lines and you must realize that you are on your own and need some level of understanding to finish the build. You must also consider that at greater voltages, dissipation becomes a major issue, even if you have big sinks, as the fets will be operating at a high level, despite what the sinks are able to do in getting rid of that heat. In my opinion, If you want higher voltage, you must begin to increse the amount of output pairs in order to bring down the individual temperature of the fets. Then the focus is again shifted to the sinks and their ability to dissipate heat.
The F5T V3 is a beast of an amp. There are speakers that need more, but i would venture to suggest biammping or buying some Pass Labs products.
...Shape the sound , Man!
Old 3rd December 2012, 06:50 PM   #585
BigE is offline BigE  Canada
BigE's Avatar
AndrewT,
I heard NP says to use 1.3 as the multiplier instead of 1.414 when calculating the expected rail voltage when for a class A amp. Then, 36 VAC secondaries make for 46.8 rails, with the bias droop built in. That agrees very closely with your observation. It will have no trouble making 100 watts.
The 1.3 multiplier makes 30 VAC become 39 volts, when accounting for droop, but that won't quite make 100 watts. Close enough maybe? Only dazed2 can say.
Old 3rd December 2012, 06:53 PM   #586
with 39V rails, you end up at around 75W at 8ohms
1.3 ratio is almost spot on in classA amps.
Old 3rd December 2012, 08:20 PM   #587
BigE's Avatar
I am missing something here. Perhaps someone can help.
Suppose Prms = 100 watts into 8R0 -- pure resistive so that the current and voltage are in phase.
Then,
Prms = I^2 * R => I^2 = 100/8 = 12.5
so, I = 3.54 amps RMS
Then, Vrms = I*R => 3.54 * 8 = 28.28 volts RMS
(check P=IV =3.54*28.28 = 100 )
Let Vrms = Vsec -- the transformer secondary.
Now, Vrail = Vsec * 1.414 = 40 VDC (the peak voltage)
Using a factor of 1.3 instead of 1.414 for losses due to class A biasing, means to achieve a 40 VDC rail, you need a 40/1.3 VAC transformer => 30.75 VAC.
This suggests that 100 watts RMS is possible from a 30.75 VAC transformer.... but that's not right, is it?
Can someone please point out where I blew it?
Old 3rd December 2012, 10:27 PM   #588
Sin Bin
And you know this how .....
Old 3rd December 2012, 11:18 PM   #589
buzzforb's Avatar
Lets just say i had a single channel of the V3 working a month ago. Ran one speaker with V3 and the other with V2. Could hear a difference and I dont need but about 2W. The pretty versions always take longer., as you know.
Old 4th December 2012, 08:47 AM   #590
Originally Posted by BigE View Post
I am missing something here. ..........................
go and look at the F5 pdf.
It states a +-25Vdc supply and yet the maximum output is ~20Vpk
That difference (or loss) is due to current passing through the semiconductors and actual resistances, from supply to the terminals and then back to the supply.
The same applies to all amplifiers.
regards Andrew T.
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
