F5 Turbo Builders Thread
Old 2nd December 2012, 05:19 PM   #571
AudioSan is offline AudioSan  Norway
what's the sec voltage for that 1KVA transformer?
Old 2nd December 2012, 11:45 PM   #572
anilva is offline anilva  India
Originally Posted by dazed2 View Post
Anivila, great job!
Thank you for the review of your impressions against the F5. What you said is exactly the reason I am about to embark on building the V3
BTW how did you go about tuning harmonics using P3?
I did not tune the harmonics yet. The wiper of 200 ohms preset is set in the middle. I don't have the means to measure distortion nor do I have access to scope. Will attempt one of these days, if I can do it with a borrowed scope.
The secondary voltage of the toroid is 24v per winding.
DIY F5T, F6, Aleph J, M2 & 45/2A3 DHT SET Amp, Fostex 206 based BLH, Altec 515 LF & 288 HF Onkens, Tannoy HPD Speakers. EMT950, Technics SP10, Garrard 401, TD124 turntables.
Old 3rd December 2012, 12:02 AM   #573
2x24V transformer is useless for V3. you vill not get any more power from it, then from V2.
you need about 2x35V transformer to hit the magic 100W class A number at 8ohms.
Old 3rd December 2012, 12:18 AM   #574
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Testing harmonic structure means buying a soundcard and getting free software like ARTA or Visual Audio analyser. Audio San is correct that you would have plenty of available CLass A current, but would be voltage limited.
...Shape the sound , Man!
Old 3rd December 2012, 12:31 AM   #575
dazed2 is offline dazed2  Canada
Wow, so at 35V secondaries, are we running 45V rails? would 50V caps be at the limit! starting to get expensive
Old 3rd December 2012, 12:40 AM   #576
with 50V caps on 45V rails you have above 10% headroom.
unless you run the PSU unloaded.
Old 3rd December 2012, 12:50 AM   #577
I completely missed this fact. I agree. I might get higher current capability with more number of output devices but there will be no higher voltage swing. Looks like I need to order a 35V secondary trafo for V3.
Old 3rd December 2012, 12:51 AM   #578
I do have decent sound cards including an external USB M-Audio device. I need to check on the software.
Old 3rd December 2012, 03:19 AM   #579
a.wayne is offline a.wayne  United States
Sin Bin
Lol ,
magic 100watt what makes 100 watt @8 ohm magic .....?
Old 3rd December 2012, 03:52 AM   #580
Just did some quick calculation. Please tell me if I'm wrong.
at 100W into 8 ohm you will need 26.83VDC at the speakers. Since we need to calculate it in ACV then we multiply by root 2 or 1.414 thus giving us about 40V rails.
Using NP's approximation 40V rails would require about 30V secondaries at the transformer.
Is this correct?
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
