Old 25th November 2012, 10:59 AM   #551
buzzforb's Avatar
Andrew, are you saying you thought it wad p3? Seems unlikely based on description.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 25th November 2012, 11:40 AM   #552
anilva is offline anilva  India
Originally Posted by AndrewT View Post
I said a long time ago that the adjustment VR needs fixed resistors either side to limit the extent of adjustment. Seems folk either don't read or have a memory as bad as mine.
I agree with you. There seems to be a need for protection around how much you can play around P3 without severe damage.
DIY F5 Turbo V3, DIY F5 Turbo V2, DIY F5, DIY F5 Toshiba Dual output, DIY Aleph J, DIY Fostex 206 BLH, DIY Altec Onken with 515B LF & 288H HF, Behringer Digital Xover, Technics SP10 MKII & SL-1210, EMT938 TT.
Old 25th November 2012, 11:46 AM   #553
buzzforb's Avatar
I really dont think it was p3. I think it just points to a problem around the n channel jfet.
Old 25th November 2012, 12:14 PM   #554
f5 turbo manual states ""It differs mostly from the original by the inclusion of P3, which
aids in tweaking the symmetry of the circuit for the lowest possible distortion""
It is only for fixing the distortion.
Old 25th November 2012, 12:20 PM   #555
That is exactly how I understood as well and hence was not careful with the tweaking. Little did I realize that it can blow the jFets if adjusted improperly. I have also noticed that it has impact on output offset and bias levels of the MOSFETs. I think I prefer now to leave it out completely or set it to middle of the trimmer range before soldering.
Old 25th November 2012, 12:25 PM   #556
buzzforb's Avatar
Exactly. I dont think it can throw the balance off baddly enough to cause a major fault, like was experienced by anilva.
Old 25th November 2012, 12:28 PM   #557
buzzforb's Avatar
Anilva, i dont beliebe this was your problem. You had an existing problem that was made worse by P3, but not caused by P3.
Old 25th November 2012, 05:39 PM   #558
sangram is offline sangram  India
What happens if there is a short circuit from wiper to one of the jfet source pins? Would it not affect the DC gain (and therefore the current drawn through the jfet?).
The symmetry adjustment offered by P3 is (probably) to adjust for the difference in transconductance between P- and N- channel devices, and the only way it does that is to adjust the DC parameters around the jfet source. euvl and jackinnj had alluded to using slightly different values in the two halves of the circuit a year or so ago, P3 was a way to make it adjustable without having to desolder.
I guess my PCB and build will be redesigned to have a lower value of P3 with a couple of series resistors on each leg. Lower adjustment ratios but lower risk too.
Old 25th November 2012, 05:44 PM   #559
buzzforb's Avatar
Guys. pot centered, you have 9 ohms of degeneration for each jfet. Swinging it fully in either direction leaves you with 8 and 9.5. Not a significant difference. It could easily be adjusted out on the output. He had problems before adjusting the pot. THere was something wrong to begin with. Unless ZM or Nelson says otherwise. I would assume it was not the pot.
Old 25th November 2012, 05:50 PM   #560
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Fire up the 4 pr and show him buzz ....
F5 Turbo Circuit Boards chchyong89 Pass Labs 2131 23rd May 2013 10:36 PM
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
B1 builders thread Bas Horneman Pass Labs 688 27th February 2013 11:15 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2013 diyAudio
