#511 | ||
Thanks.
DIY F5 Turbo V3, DIY F5 Turbo V2, DIY F5, DIY F5 Toshiba Dual output, DIY Aleph J, DIY Fostex 206 BLH, DIY Altec Onken with 515B LF & 288H HF, Behringer Digital Xover, Technics SP10 MKII & SL-1210, EMT938 TT. |
#512 |
Is that Idss measured in circuit or before installation. Are both channels showing that Idss? That seems high for a degenerted BL grade. IT is possibly too high in terms of dissipation, but ZM may have more insight in this particular area.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#513 |
IDSS rating given by spencer and is measured before the installation.
#514 |
Nice case, Anil
![]() Bad input FET is what it might be. There was someone who had the exact same problem on the F5 thread and there were some questions on being able to set the bias with a busted jFET, but apparently it is possible. I wouldn't worry about desoldering from a double sided board. Just snip off the leads and solder the new transistor on top of the pad (no need to go all the way through). Works when the holes won't open up. Mostly though, a hot iron (very hot) an bit of solder to get the flow going, and some solder wick does the job of opening up great for me. Never had an issue even with very tiny through hole components. Good Luck, the amp looks nice! |
#515 |
In circuit should measure between 5-6mA.
#516 | |
First I will measure and compare the working and the problematic boards before I change any component. Surprisingly the amp biases very well. Cheers.
#517 |
I have everything except the PCBs, and it's on hold till my home renovations are completed in December
![]() Do eliminate any errors in the input circuit as well, track the signal before it hits the input stage. Small oversights could be the case here. |
#518 |
Anyone do a recent purchase of Heat Sink USA 10.08 profile, care to comment on product flatness?
Apparently there has been a flatness problem in the past and HSUSA stopped production for a while to improve their process? |
#519 |
IT is a problem, but only if yo plan to couple two sinks together and then mount to the coupling device. I am in the middle of trying this very thing, but find time a bit sparse.
#520 |
i have this sinks. got them summer of 2011. and have 2 side by side. i do not have any problem with flatness.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
| B1 builders thread | Bas Horneman | Pass Labs | 690 | Today 11:59 AM |
| F5 Turbo Circuit Boards | chchyong89 | Pass Labs | 2143 | Yesterday 07:18 PM |
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
