#501 |
the dissipation numbers are correct.
500VA will work. but a 600VA will give you lower transformer temp and more headroom. you can also use bigger transformer if you like. i often use 3x transformer rating to get the temp down.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#502 |
Regarding heatsinking how do I calculate the Tj for multiple transistors on the same sink?
Single transistor: Tj= 25+(32x(0.83+0.1+0.28) where 0.1 is the keratherm pad and 0.28 is a big 200x200x40 heatsink. Tj=63.72C now if I double the power dissipation I get: Tj= 25+(64x1.21)=102.44 but this formula doesn't account for 2devices, just 1 dissipating double the power. How do I introduce the 2nd transistor In the formula? |
#503 |
the first term 25 is Ta, is that a reasonable ambient temperature to use?
the second term 32 is the device dissipation. You must put in there the actual device dissipation. you must split the last three terms. 0.83 is the device Rth j-c, use this for each single device. 0.1 is the Rth c-s, use this for each single device. 0.28 is the Rth s-a this must be de-rated to take account of the lower deltaT, use this after de-rating for all devices on the sink. back to Ta. In Scotland I would use 28degC since I don't have air conditioning. What would you use for summer Ta? Last edited by AndrewT; 24th October 2012 at 11:24 PM. |
#504 |
I understand the formula when used for a single device. what I can't figure is how to write the formula for 2 or 4 devices on the same sink.
Example: f5t with 4 devices on a sink with 0.20w/c with 1Abias @32v how would I lay the formula? Ps: Summer Ta would be 30c worst case I think. Must measure next summer
#505 |
Ta=30
Ts= Pdtotal * Rth s-a * DF. try two dives @ 25W each & Rth s-a = 0.28C/W measured @ deltaT=75Cdegrees. Ts= 30 + [2*50*0.28*DF] = 30 + 28Cdegrees. 28 is <<75 so DF >>1.00 manufacturers data may say use Df=1.3 Ts= 30+28*1.3 = 66degC Tc= 25 * 0.1 +66 = 68.5degC Tj= 25*0.83 +68.5 = 89degC Tc is needed to calculate the temperature de-rated SOAR. |
#506 |
I am about to bias up my F5T v2. I have separate heatsink for each of the MUR3020W diodes near the output devices.
Since I am fraidy cat as Papa puts it, I can start by biasing upto 0.3v on 1 ohm resistor to begin with. My speaker load is nominal 8 ohms and is not going to go very low at all. My question is where do I go after that. My heatsinks are pretty huge and actually meant for v3 and I expect them to run only warm and not hot. Is there a way to push the bias further than 0.3V ? I want to run as much as possible in Class A mode. Thanks.
DIY F5 Turbo V3, DIY F5 Turbo V2, DIY F5, DIY F5 Toshiba Dual output, DIY Aleph J, DIY Fostex 206 BLH, DIY Altec Onken with 515B LF & 288H HF, Behringer Digital Xover, Technics SP10 MKII & SL-1210, EMT938 TT. |
#507 |
The factor that determines the maximum current you can bias you r output to is the Vdrop across the Rs and heat. If you can deal with the heat, you simply need to change the Rs value to whatever will give you your desired bias, while dropping no more than 3-400mV, like in the article. Example. 2A bias would need .15R resistor to give you a safe V drop for the diodes.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#508 |
Completed building F5T v2 exactly as per the schematic using boards designed by fellow member Om Mishra as a part of a group buy on an India forum.
Heatsinks are massive 20 KGs per meter heavy duty ones. Pictures are enclosed. The amp biases nicely and have biased to 350 mv on each channel. Provided individual heatsinks to each of the switching diodes at the outputs. Gets to around 40-45 degrees centigrade. Tried playing music. One channel plays really well and on the other channel there seems to be no gain, with very feeble output. Every resistor is measured and soldered. There cannot be too many errors on the solder as I have gone through each solder with a magnifying lens before powering on. The power supply is showing 33.5 on each rail on load condition. Could it be the case of a bad jFet pair on the bad channel? Don't know where to look. Need help from the gang please.... Cheers.
#509 |
make a break for few days
after that , go back and compare channels visually then power up and compare them with DMM
my Papa is smarter than your Nelson ! tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
#510 |
Bad jfet is easy. Test V drop across source resistors. Take voltage readings at various places, starting with FE. Report back. All this after taking a break, as ZM suggested. It is amazing how many mistakes I have found after taking some time away from a project.
| F5 Turbo Circuit Boards | chchyong89 | Pass Labs | 2115 | 11th May 2013 08:18 PM |
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| B1 builders thread | Bas Horneman | Pass Labs | 688 | 27th February 2013 11:15 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
