F5 Turbo Builders Thread
Old 9th October 2017, 06:20 AM   #4861
vemsom is offline vemsom  Sweden
Originally Posted by Zen Mod View Post
nope , just leave it in mid position
confirm that with ohmmeter prior to soldering it on pcb
It's in the middle position since the build, but still the P3 was put there for the purpose of choice, wasn't it? Both Pass and other build guides wright about using it for tweaking and perfecting the amp by taste.
Is there anyone who know how to set it and could give me a actual guidance other than leave it as it is (I'm aware of that the middle point might be where I end up at the end).
Old 9th October 2017, 06:21 AM   #4862
Originally Posted by neno70 View Post
x F5 turbo v2, example Psu just one x the way the channels ?? thank you
Thats enough for both channels, use a transformer with minimum 600VA rating.
Old 9th October 2017, 06:50 AM   #4863
neno70 is offline neno70
thank you
Old 9th October 2017, 07:12 AM   #4864
ColinA123 is offline ColinA123  United Kingdom
Either,
You have sophisticated distortion analysing equipment, and you set the harmonics to your "ideal" value.
Or,
You tweak it and use the Mk.1 ear to pick your favourite position.
Alternatively you set it to mid point and leave it alone.
Old 9th October 2017, 07:25 AM   #4865
Originally Posted by ColinA123 View Post
Either,
Or,
Sorry for sounding grumpy, but this is another answer without any information.
I already said in my first post that you could listen your way to the right position and know ill be able to do a blind tweaking. No matter what i end up, the distorsion i choose to go for doesn't matter, I still like to know if for ex. clockwise will boost 2nd harmonics.
Old 9th October 2017, 07:36 AM   #4866
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
you can hardly get two channels identical only by ear , but you can always try
there is no recipe "turn clockwise 1.3489 turns to get 8.62db of difference....", simply because there are too much variables
satisfied now ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 9th October 2017, 07:40 AM   #4867
satisfied now ?
Wouldn't x amount of turns in either direction be the same for both channels?
Does it take, like you say around 1 turn in either direction or is it more like 10 turns before any noticeable change comes?
Old 9th October 2017, 09:07 AM   #4868
Zen Mod's Avatar
there is no recipe ....... simply because there are too much variables..........
Old 9th October 2017, 11:48 AM   #4869
Dennis Hui is online now Dennis Hui  Canada
6L6 did a video on adjusting P3:
Adjusting P3 - a video
We are fearless amplifier builders. A little heat doesn't scare us at all.
- NP 2002
Old 9th October 2017, 06:33 PM   #4870
Great, and even some instructions on how to set it.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
