F5 Turbo Builders Thread
Old 12th August 2017, 03:10 PM   #4801
Erlend Sæterdal is offline Erlend Sæterdal  Denmark
Any experience with floating ground in the F5turbo?
Old 12th August 2017, 07:36 PM   #4802
Had a huge hum problem with 2 channels at the input. With only one nothing at all. Solution must be a little resistor in the gnd in?
Jims Pcb
Erlend Saeterdal - Erlend Saeterdal added a new photo. | Facebook
Old 16th August 2017, 06:48 AM   #4803
vemsom is offline vemsom  Sweden
Jims Pcb
Have you tried the PSU / grounding suggested by NP for the f5 turbo?
Old 21st August 2017, 06:11 PM   #4804
R.I.P.
Please note the different symbols used for the chassis ground/Safety Earth/PE and the PSU power ground/PSU zero volts.
This is important.
Note also that the secondary centre tap goes directly to the first capacitor pair.
having got those bits wired correctly it becomes important to minimise the loop areas of the charging circuits to minimise the EMI.
regards Andrew T.
Old 21st August 2017, 08:04 PM   #4805
Thanks Andrew but I use BUS. I realized it is not possible with only four rectifiers pr. channel. So I will use 8. The reason is common transformer. I think bus results in better sound.
Old 22nd August 2017, 08:32 PM   #4806
Liliya is offline Liliya  Norway
BUS?? Explain. Drawing?
Eivind S
Old 22nd August 2017, 09:04 PM   #4807
Originally Posted by AndrewT View Post
Why are you doubling up the hard-wiring of the smoothing caps?
Bring the rectifier in at one end. Take the power out at the other end.
Eyvind this is what I call "bus"
Old 23rd August 2017, 04:49 AM   #4808
Default Gnd enclosure
As my backplate is not metal I could have a problem with electrical connection of the enclosure parts. I'll connect the two heatsinks at the backplate with a copper 2 cm wide and ground my input to that trough 10 ohm and a capacitor. Do you think that's an idea? ? I can't post pictures even that I have paid Diyaudio 20 dollars for membership.
Old 23rd August 2017, 08:04 AM   #4809
R.I.P.
.......... I can't post pictures even that I have paid Diyaudio 20 dollars for membership.
Don't post pictures.
Attach them !
How to attach images to your posts.
And registration here is free.
regards Andrew T.
Old 31st August 2017, 08:18 PM   #4810
Thats what I try to.
Have anyone tried other rectifiers then MUR 3020 for the turbo? I think they are very bad sounding.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
