F5 Turbo Builders Thread
Old 10th October 2012, 03:02 PM   #471
kroyin is offline kroyin  India
Yes and they are 10.1 mA & I'm doing the V2
Well Google threw up a good DIY TO-92 heatsink solution ..
I'll give that a try
Old 10th October 2012, 03:21 PM   #472
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
TO-92s aren't designed to shed much heat. Heatsinks aren't much use with them.
Old 10th October 2012, 03:23 PM   #473
buzzforb is offline buzzforb  United States
buzzforb's Avatar
With 32 v rails, Nelson advises either cascoded FE or more degeneration. Otherwise you are really pushing the jfets. Add to that th einternal case temp.
...Shape the sound , Man!
Old 10th October 2012, 03:46 PM   #474
Thanks everyone..as per manual
A wise DIYer will either select a Jfet with a lesser Idss (say 8 mA) and/or see to it that the Jfets gets some cool air or a little heat sink. Or you can cascode them
Cascoding is out of equation ..8mA with heatsink & air(no problem we have ceiling fans :-)) it will be
Old 10th October 2012, 04:33 PM   #475
buzzforb's Avatar
Point is simply to watch temperature. What path you choose is up to you. A jfet with higher idss, has higher yfs, and as a result, is more linear with lower distortion. I would get as high a idss fet that i could find and cascode or degenerate, butthats me.
Old 10th October 2012, 08:03 PM   #476
R.I.P.
I was thinking about starting a thread titled "shaving To92 transistors to improve performance".
But I have little to get started with, other than I have filed a couple down to 1mm thick, 0.5mm either side of the leg locations and they still appear to work.
regards Andrew T.
Old 12th October 2012, 11:58 PM   #477
Meganinja is offline Meganinja  Australia
Hi
The original F5 is enough power for my situation , but if I want to upgrade the F5 to this new F5 non turbo( not to install power diodes ) to drive speaker 4 ohm load ,and to cut cost further can I reuse old power supply that is +- 24VDC and the four 100 ohms remain , I do not mind a bit of power lost , because it is a lot easier , just a drop in replacement PCB module,Thanks for your help.
Old 13th October 2012, 01:19 AM   #478
a.wayne is offline a.wayne  United States
Sin Bin
Got yours up and running yet ..?
Old 13th October 2012, 01:33 AM   #479
buzzforb's Avatar
HA!
Old 13th October 2012, 01:48 AM   #480
Hi
Did you file the flat side of TO92 , is this the max limited you can file ?Can it be filed a bit more ? I am thinking of filing the pairs Jfets to improve thermal condition ie.. 2 jfets filed and glue together .
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
