F5 Turbo Builders Thread
Old 19th June 2017, 10:18 AM   #4751
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
fiddle with P3 will give more results than any fiddle with made of preputium parts
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 22nd June 2017, 10:40 PM   #4752
Bfpca is offline Bfpca  Canada
I've just got my mono block F5t amps wired up and am in the testing phase. I am unable to get past about 230mv of bias using some store bought 74/170. They are the b grade but are at the extreme low end of the range.
I am measuring just less than 6ma of current and am unable to get enough voltage across the 1k/5kpot combination to get past 230mv. The bias is slightly over compensated thermally by the thermistors. It actually goes down a bit as the amp warms up. This may be because I am at the high end of the adjustment range on the 5k pot. which makes the voltage across the 1k more sensitive to changes in the thermistor value.
I am thinking of changing out the 1k for 1.2k. Any other suggestions are welcome.
I am also getting offset drifts of maybe 40mv from cold to hot which seems to be fairly common. This is much trickier to adjust than my Aleph J which locked onto it's bias setting and maintains a low offset as it warms up.
Old 22nd June 2017, 11:26 PM   #4753
Zen Mod's Avatar
Originally Posted by Bfpca View Post
I am thinking of changing out the 1k for 1.2k. ......
good for start
Old 23rd June 2017, 12:01 AM   #4754
laverda is offline laverda  United Kingdom
I had the same and ended up with 2.2k/5k pot as that was all I had knocking around which worked well for me. About 10 turns on the 20 turns pot for 250mv bias.
Offset, you should be able to get within just a few mv, even 0mv for a while. Mine runs less than 5mv after about 30-45mins. I ignore the cold mv reading ...
Old 23rd June 2017, 12:37 AM   #4755
After I get the bias up to my intended target of 250mv -(2 amps total) I'll start to adjust for low offset. My chassis are not that large, being 150mm high and 400 deep, but they have 10mm thick sinks with a total depth of 50mm versus 8mm and 40 total for the store chassis. At 225mv -.45amps/fet with a 48v supply the hottest temp I can find with an IR thermometer is 110f. The sinks and transistors are not what I would subjectively call hot after 45 minutes but just warm. I'm thinking .5amps/fet is doable , maybe a little more. I am not using the diodes, I just don't think they are worth the trouble for the loads I am going to drive. With 4 sets of outputs/channel the diodes don't get you much extra output with 4-8ohm speakers.
Old 23rd June 2017, 05:14 AM   #4756
daniii88 is offline daniii88
I get an offset drift of about 400mV from cold to hot. So I still quite don't understand from where it is coming....
Maybe i should change R11 / R12 resistors to some other value... But in which direction to go, more or less?
Old 23rd June 2017, 09:54 AM   #4757
100degreeF (43degreesC) is quite cool for a ClassA amplifier.
That leaves much leaway to go higher.
The bias voltage required to turn on the outputs is the Vgs of the two outputs.
That bias voltage comes from the Drain Loads on the input stage.
The Drain Loads are a parallel combination of resistors and variable resistors.
The current through those Drain Loads is less than Idss of the jFETs.
If you use 7mA jFETs and they pass 6mA in the circuit, then the Bias voltage will be 0.006A * Drain Load resistance in ohms.
i.e. a Drain Load of 500r will allow a bias voltage of 3Vbias.
If that is too low to turn on the output, then change the drain load, or change the jFETs.
Going from 1000r to 1200r will increase the available bias voltage. Try it, but I think you will need to go higher. Maybe 1300r, or even 1500r.
regards Andrew T.
Old 23rd June 2017, 11:49 AM   #4758
Andrew - I was going to go to 1200 because I had 4 of them in stock but I found I still had 4 1500r left over from my Aleph J build so I'll swap them in today and re adjust bias.
Danii88- that's a lot of bias drift. Thinking about this drift I wonder if some of it is coming from the thermistor temperature compensation.
I made sure I had consistent mounting orientation and contact with the MOSFET on all the thermistors. Check yours for alignment. It's easy for them to get bumped and bent out of place. The VGS of the N and P sides of the output stage are offset a bit. I am wondering if this causes the temp compensation to be offset as well and that as the amp warms up there is a drift in offset due to this. I haven't reasoned this through yet but it seems like a possible source of offset drift. If so we may be able to reduce the drift by adjusting the series resistor in the temp compensation circuit.
Old 24th June 2017, 01:27 AM   #4759
Changed r5/6 to 1.5k and I can now bias at 250mv.
Old 24th June 2017, 09:00 AM   #4760
is it able to go to 260mVbias? or to 270mVbias? or to 280mVbias?
I would turn it up as high as 300mVbias for a minute or so, just to see how far it will go. The sinks will take a while to catch up.
regards Andrew T.
F5 Turbo Builders ThreadHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 07:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 08:14 PM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
