F5 Turbo Builders Thread - Page 40 - diyAudio
Old 31st August 2012, 04:35 PM   #391
or one can start with 100ohm on each side of the wiper of P3, adjust it to 0mV and see how much offset one gets when P3 is adjusted all the way to each side.
Old 31st August 2012, 05:40 PM   #392
buzzforb's Avatar
Remember it is 100 ohms in parallel with each 10ohm resistor. Big difference.
...Shape the sound , Man!
Old 31st August 2012, 05:42 PM   #393
i know. but a 200ohm pot set in the middle is 100ohm from wiper to each end pin thats what i ment
Old 31st August 2012, 05:45 PM   #394
buzzforb's Avatar
Gotcha.
Old 31st August 2012, 06:04 PM   #395
here is a cat that has stamped in ink and running over paint trying to describe what i ment
Old 31st August 2012, 06:08 PM   #396
ups. a little smal
what. hmmm. can't get it bigger.
Old 31st August 2012, 06:23 PM   #397
if this works. then maybe one will do with a single turn pot(50ohm)
and don't need display and ohm meter
and ofcourse. one can have a switch inside the amp, to switch between multiple resistor settings. and adjust offset from there. f.ex if you switch speakers or something else
and use the pot to adjust after type of music
Old 1st September 2012, 09:42 AM   #398
Audio.
crop your pic before you save it.
then you can attach a sensible size to your post.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st September 2012, 09:50 AM   #399
buzzforb's Avatar
If it were me, i would define 3 settings and use a selector switch. I am sending out the GB kits Mondat, so hopefully this thread will light up soon.
Old 1st September 2012, 11:35 AM   #400
buzzforb's Avatar
I am going to show the monblock setup i have been talking about tomorrow. It is not ideal due to the unflat back of the 10.08 HS i got from HS USA. They are currently retooling to with a focus on a nice smooth and flat back for instances just like this. It is the reason they have been out of production for a while. Mine will work, but it puts the heatsink back on an uneven plane and will show up when the lid and bottom are added. It should still show a method that would allow the use of TeaBags boards, ChipAmp PSU, and possibly trado in single monoblock. I know this will open things up for some folks in building the larger versions.
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
