F5 Turbo Builders Thread - Page 38 - diyAudio
Old 16th August 2012, 11:23 PM   #371
buzzforb's Avatar
Disaster just means having to build something else
...Shape the sound , Man!
Old 16th August 2012, 11:50 PM   #372
CeeVee is offline CeeVee  Portugal
CeeVee's Avatar
I run them a little above half rated voltage... extremely silent.
All you really need is to get the air moving a little, makes a huge difference here in Lisbon summer
Old 16th August 2012, 11:58 PM   #373
buzzforb's Avatar
Absolutely. I built a box with dual 120mm fans pulling across a single 10" x12" heatsink and was able to run 300w. It got hot in the room quickly.
Old 17th August 2012, 02:44 PM   #374
Horio is offline Horio  United States
Horio's Avatar
Originally Posted by buzzforb View Post
Spreading audio porn all over tonight
Very cool buzz. Looking forward to seeing how those heatsinks work when you throw a couple more pairs on there. They look like the 10" profile sinks for heatsink USA, which I was thinking of using for my build.
Old 17th August 2012, 02:57 PM   #375
buzzforb's Avatar
If i go with 4 pairs, I will use a single 1R resistor and cut the bias in half. I don't need more power, so it is just a matter of whether or not I like 4pairs@400mA or 2pairs@800mA. IF I like the 4 pair, I may try 4 at higher bias as well, using monoblocks. The heatsinks are very similar to the HS USA 10", but not the same. I have the HS 10" waiting in the wings. BTW, I should be packing the kit stuff in the next week or so. Also. I should be listening to a standard vs upgraded version of the F5T tonight. Little comparison.
Old 17th August 2012, 03:01 PM   #376
CeeVee's Avatar
If i go with 4 pairs, I will use a single 1R resistor and cut the bias in half. I don't need more power....
This my exact situation, i'm very curious to hear your subjective experience about these two possible choices.
Old 17th August 2012, 03:04 PM   #377
buzzforb's Avatar
I hope to measure the current two pair version this weekend and then do that as well for the 4 pair version. Too much subjectivity is trouble around here.
Old 17th August 2012, 03:28 PM   #378
CeeVee's Avatar
I know , the subjectivity i refer to is the comparison between a cooler running class a amp and a hotter ( better sounding ? ) one as has been expressed in many post.
I'm guessing a 4 pair one should have a cleaner punchier bass...i might be wrong
My subjective reasoning is that current delivery to load should be quicker with 4 pair but that has to be possible also by the PSU.
????? let us know
Old 17th August 2012, 03:42 PM   #379
a.wayne is offline a.wayne  United States
Sin Bin
Yes, welcome ....... 8cylinders beat 4 cylinders ... for smoothness and delivery all the time .............
Pour it on , I gotcha back bro .....
Old 31st August 2012, 03:29 PM   #380
hello. just got a great idè regarding P3 trimmer for this amp, and all other F5's for hat matter.
how about a multi turn panel mount pot, connected to a digital ohm meter with a smal display on the front? that way you can easely get 2 monoblocks adjusted the same.
and for a stereo amp, one gan use a stereo pot with one ohm meter and display.
what do you think? and do anyone know who can be selling ohm meteres that can be used(that you can calibrate yourself)?
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
