F5 Turbo Builders Thread
Old 23rd August 2014, 07:20 PM   #3531
BigE is offline BigE  Canada
BigE's Avatar
Spikes on the output of the PSU or on the amp?
ZM,
I think the soft start he is referring to is the toroid, not a slow charge on the caps.
Old 23rd August 2014, 07:28 PM   #3532
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
in any case -Egg needs to observe DC at cap bank in moment of mains soft start relay(s) energizing
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...Đ by Mighty ZM
Old 23rd August 2014, 11:45 PM   #3533
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Nash:
I suspect the hole sizes on the new F5T pcbs are the same as the version I used. To make a good connection using stranded 14 gauge wire, I cut away just enough of the strands to allow those that would fit through the holes to do so. The strands that were cut shorter were all cut to the same length, so they ended up "kissing" the top surface of the solder pad. I soldered the longer strands on the rear side of the pcb and added solder on the top side as well, so the shorter strands would be contained and connected to the solder pad.
Scott
Good decisions are derived from experience; experience is derived from bad decisions (unknown)
also, "Love + Time - Distance = Hate" (Louis C.K., 2017)
Old 26th August 2014, 02:13 AM   #3534
nashbap is offline nashbap  United States
Originally Posted by SRMcGee View Post
Nash:
Scott
Scott,
If you look at pics of the older version and the latest you can clearly see the reduction in hole size. In the version I believe you used, you could easily get 16AWG stranded wire in and with some trimming a 14AWG stranded as you have done. If this is incorrect please let me know. What is the version # silkscreened on your boards? In the latest version you can just about get a 18AWG stranded in. That is the problem. Otherwise the boards look good.
Any luck sorting out the "thinness" in sound you complained about?
Nash (Southern NJ)
Old 26th August 2014, 10:28 PM   #3535
leifchristensen is offline leifchristensen  Norway
hello folks
have some problems with my F5Turbo
having problems with offset and started to measure bias at the different 1R pairs by the output devices
Across PNP side
R17 and R18 365mV
R19 and R20 352mV
Across NPN side
R21 and R22 368mV
R23 and R24 344mV
Offset approx 5mV
Is this sign of badly matched output transistors or normal?
best
Leif
Old 26th August 2014, 10:32 PM   #3536
6L6 is offline 6L6  United States
6L6's Avatar
Your bias readings are actually quite good - remember you are comparing N and P channel devices.
If your offset is stable at 0.005V (5mV) it's set very well!!
Is there any offset drift once the amplifier is power on for 45-60 minutes? If no, you are done. Connect speakers and enjoy!
Old 26th August 2014, 10:41 PM   #3537
it takes close to an hour to reach thermal stability and these bias readings
but what about the difference within the PNP and NPN devices?
arenīt they too big?
donīt like that offset starts way ahead (about 90mV) and creaps slowly down
not good for compression drivers (TAD4001 and 2001)
approx 33vdc supplied from choke input supply and 1kva 40vac powertransformer
best
Leif
Old 26th August 2014, 11:13 PM   #3538
6L6's Avatar
That's about normal, the big amos take a while to get to thermal stability.
No. In fact, your devices are quite close. Anyway, the N and P Vgs rarely, if ever, match
donīt like that offset starts way ahead (about 90mV) and creeps slowly down
... that's part of it being an F5. You may want to install a relay or switch on the output if you are concerned.
Old 27th August 2014, 12:42 AM   #3539
Zashoomin is offline Zashoomin  United States
I apologize in advance for being such a noob. I have been doing research and have read about 300 pages of this thread and am still confused on a bunch of things.
I was planning on building F5T V2 or V3 monoblocks, but am not sure which one is better suited for my needs. I am looking to get 100W class A into 8ohms.
First of all the Mosfets. The recommended FQA12P20/FQA19N20 seem to be very hard to find unless you want to risk buying them from china. Does anyone know where to source these? Then there are the Toshiba offerings (2SK1530/2SJ201) which because of their lower current ratings may or may not work, but are also very hard to find. Finally the ones that are still in production seem to be the FQP12P20/FQP19N20, IRFP9240/IRFP240. Which is recommended?
Old 27th August 2014, 01:10 AM   #3540
6L6's Avatar
Use the IRFP240/9240 The factory-build Pass amps are using them. If they are good enough for Papa, they are good enough for me.
You say you need 100W into 8R...
What kind of speakers do you have, how big is the room, what kind of music do you listen to, and (be honest) how loud do you like it?
And can your room deal with the heat from an amp that big?
F5 Turbo Builders ThreadHide this!Advertise here!
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 08:14 PM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
