F5 Turbo Builders Thread
Old 26th April 2014, 04:50 AM   #3211
BobEllis is offline BobEllis  United States
BobEllis's Avatar
You're measurements make no sense at all. You cannot have a different reading across C5 and R27. Your technique is flawed or you are not matching your measurements to the schematic correctly. You are showing 30 mA base current in the cascodes and 1.5 mA collector current. You also have 10x the current in the cascode base stoppers as there is in the voltage divider. These readings defy physics.
Try this way: attach the black lead of your meter to ground and LEAVE IT THERE! Now move just the red lead to the various points and record the readings. Don't worry about the voltage across components, we vs easily calculate that from the voltages at each end. I'm wondering if it is working fine it's just your measurement technique is totally FUBAR.
Old 27th April 2014, 03:08 AM   #3212
dazed2 is offline dazed2  Canada
Bob,
Yep you're right, I made some measurement mistakes. Here are the new measurements. attached black to ground and move the red around.
However, the measurements at Jfet is stil the same. 0.6V on K170 and 0,54V on J74.
BTW.... I was careless... and touched the probe across two resistors.... and let the smoke out.... scare the daylights out of me ! iIn fact blown two or three resistors So whatever BJT and jfets that was there, there are most likely blown now .
This is what I got before the magic smoke left.
Sooo anyone have a few jfets and bjt's lying around.....
Old 27th April 2014, 07:17 AM   #3213
BobEllis's Avatar
Something is seriously amiss with your cascodes. The voltage divider seems to do its job, giving you ~+/-16V but there is a huge voltage across R29 and R30. Double check their values. The cascode transistors are the next suspect. They shouldn't draw much base current (little to no voltage across R29/30 is normal)
What was your rail voltage before your accident? What are the part numbers on your BJTs? Read them off the part, and verify that they are in the proper place.
Old 28th April 2014, 04:08 AM   #3214
Yes the BJT's should be in the right place. I have pics of them here #3193
However. I think I figured out the issue. And it only took a burned up board for this
I took out all the components from the board to transplant the good ones to another board I have (had to buy extra set due to the double secondaries)
R29 and R30 are 475Kohm resistors, not 475ohm resistors
somehow I ordered the wrong ones
Oh well I guess that solves that now..
I haven't gotten around testing the bjt and the jfets to see if they are blown. but I suspect I need new ones....
anyone sell me a set?
Old 28th April 2014, 09:06 AM   #3215
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
both Jfets and bjts are probably alive
well - you paid your price ....... hope from now you'll check all components trice , before placing them on pcb .....
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 28th April 2014, 11:39 AM   #3216
BobEllis's Avatar
Glad you got it sorted. Enjoy your amp as you finish it.
Old 28th April 2014, 01:09 PM   #3217
BigE is offline BigE  Canada
BigE's Avatar
That is great advice....I've done the same but with less disastrous consequences.
Old 28th April 2014, 06:08 PM   #3218
Yes, and pay attention to that itty bitty little symbol at the bottom of the DMM that tells you the order of magnitude the number is .
Old 28th April 2014, 08:51 PM   #3219
nashbap is offline nashbap  United States
Get an auto ranging multimeter.
Old 28th April 2014, 09:11 PM   #3220
Actually it is because it is autoranging that I didn't realize the "Mohm" instead of ohm. If I had to physically dial the range I probably would have caught it
F5 Turbo Builders ThreadHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 07:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 08:14 PM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
