F5 Turbo Builders Thread
Old 23rd February 2014, 07:23 PM   #2991
Daniel(Del) is offline Daniel(Del)  Brazil
I shortly applied forward bias between the gate and source of one of my jfets, and left drain floating, during some idss measurement. Fortunately my psu was current limited at 15mA. It measures normally after that. Should I worry or am I good to go?
Daniel
Old 23rd February 2014, 07:57 PM   #2992
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
look in datasheet
if you didn't exceed max Ugs .........
if you did , even if just suspicious , it goes to bin
edit - I was thinking on mosfets
so , correction - if Jfet is alive , do not worry
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 23rd February 2014, 08:21 PM   #2993
Originally Posted by Zen Mod View Post
look in datasheet
Thank you ZM!
I was worried because k170/j74 datasheets list max gate current as 10mA. Since I was limited at 15mA, I thought they could become leaky or somewhat.
Old 23rd February 2014, 08:30 PM   #2994
Zen Mod's Avatar
I resumed that you tested them afterwards ;
what I meant - resuming that - if they're working , you're good
Old 23rd February 2014, 08:59 PM   #2995
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Originally Posted by BobEllis View Post
Probably not the root cause of your problem, but trim the leads going into the soft start board so no bare copper is showing for safety.
I agree that it is likely a soft start failure.
Bob:
Is the fact that adjusting P1 and P2 each changed the positive and negative sides of each channel a red herring?
Scott
Good decisions are derived from experience; experience is derived from bad decisions (unknown)
also, "Love + Time - Distance = Hate" (Louis C.K., 2017)
Old 23rd February 2014, 09:02 PM   #2996
6L6 is offline 6L6  United States
6L6's Avatar
Yes.
When the two pots get into their adjustment range, it will feel like one of them is more directly adjusting the bias (of both sides) and the other is adjusting the DC offset.
Old 10th March 2014, 06:31 PM   #2997
sts9fan is offline sts9fan  United States
Finally making progress on my V2. I know these diodes are not recommended but I had them and the PS boards could use them. Am I ruining my amp?!?
Old 10th March 2014, 06:51 PM   #2998
Zen Mod's Avatar
theз are looking big enough
besides that , I can't see more from picture
Old 10th March 2014, 06:59 PM   #2999
They are the same MUR from the amp section. I thought I had read that the fast recovery were not ideal for this sort of PS.
Old 10th March 2014, 07:20 PM   #3000
duder1982 is offline duder1982  United States
duder1982's Avatar
Keep the build process coming, I am using the same ps boards, and want to see how your amp turns out.
If I cant build it or fix it I really dont want it.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
