F5 Turbo Builders Thread - Page 265 - diyAudio
Old 30th November 2013, 01:03 PM   #2641
If you were to standardise your amp on 63V capacitors, then you will find that a 40+40Vac transformer will run with a fully biased ClassA amplifier at about +-55Vdc.
500mA bias through each pair of output mosFETs will give a device dissipation of ~27W.
Now multiply up the number of output pairs to meet your ClassA target current.
3pair = 3Apk of ClassA
4pr = 4Apk
5pr = 5Apk
etc.
The ClassAB transient current can be much higher
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 30th November 2013, 03:31 PM   #2642
BobEllis's Avatar
Originally Posted by 6L6 View Post
My specific recommendation to you - use 3 devices and bias until the transistor package is 55C with heatsinks 65C. However, either configuration you make will sound fantastic.
6L6, don't you mean transistor package at 65C and sink at 55C?
Old 30th November 2013, 03:59 PM   #2643
6L6 is online now 6L6  United States
6L6's Avatar
Lol... Yes.
I just cant type what I think this morning!
Old 30th November 2013, 05:24 PM   #2644
nashbap is offline nashbap  United States
4pr = 4Apk
5pr = 5Apk
etc.
Thanks Andrew for pointing this out. I realize that for a 100w rms into 8 ohm target with 4pairs of devices, my heat dissipation per device will be much greater with 55V rails then 45V rails given the same bias current; so for 4 pairs it would make more sense to stick with around 45V rails.
Old 2nd December 2013, 02:56 AM   #2645
dazed2 is offline dazed2  Canada
Nah, go for broke man !
Run at 55V rails! Click the image to open in full size.Click the image to open in full size.
Thats what I'm doing, 40-0-40 output trafo, for hopefully 52-55V rails, 63V caps,
lots of heat sinks, 4 case affair!
Old 2nd December 2013, 03:50 AM   #2646
4 case?? What Class A output are you shooting for? Custom heatsinks? Can't open your images.
Nash
Old 2nd December 2013, 01:20 PM   #2647
Sorry about the images, I didn't put any in there. I have no idea how they got in there? I can't seem to delete the link either?
Monoblocks with PSU's separate. 4 HeatSink USA 10.080 per channel
1.5kVa trafo's per mono.... just to be sure
going for 1000W room heaters.... I guess I won't be driving the SUV for a while.
Old 8th December 2013, 10:26 PM   #2648
BigE is offline BigE  Canada
BigE's Avatar
Has anyone considered, or better still built, an F5T with a split power supply? Ie, a lower voltage for the input fets and a higher one for the output transistors?
Old 8th December 2013, 10:52 PM   #2649
6L6's Avatar
The entire point of the cascode version is exactly that - keep the higher voltage from the Jfets, and let the outputs get to the sweetspot with the 32V (or more) rails.
The cascode fets act to keep the higher voltage from burning up the small Jfets - they are kind of an active voltage divider, and add very little sonic flavor to the circuit.
Old 8th December 2013, 11:06 PM   #2650
6L6's Avatar
Speaking of F5T cascode - (this is a 2pr v3, or probably better described as a v2 cascode...) Here are some teaser photos. I only have one channel installed in the chassis as of now.
600VA 24+24V with new diyAudio PSU v3 board, (8) 18,000uF caps.
Newest revision PCB, the new front-end will fit on existing holes in the UMS!
Biasing. I have both sets of leads reversed on the red meters, hence the negative values... Lol.
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
