F5 Turbo Builders Thread - Page 258 - diyAudio
Old 19th November 2013, 09:56 AM   #2571
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
sorry , my mistake
then , with 800VA Donut , that amount of capacity is fine
that change fuse value - needing something in range of 800/230 , so 4A seems fine
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 19th November 2013, 10:02 AM   #2572
Mallard is offline Mallard  Germany
And actually I planned to use CL30 NTC which has 2.5R and 8A. (like Mr.Pass recommended it)
But wat does it mean for the R ind the CCRCC configuration? Still .1R ok?
Originally Posted by Zen Mod View Post
sorry , my mistake
Old 19th November 2013, 10:05 AM   #2573
Zen Mod's Avatar
NP is using CL60 , in 115Vac mains area
my experience is that 10R NTC is better for this side of Big Splash , juicing 230Vac from wall
regarding CRC - no matter what size of cap bank is in question , I can't stand more than 0R1 in line
if Donut/Graetz size permits , I'm not using it at all
Old 19th November 2013, 11:01 AM   #2574
Pass uses one CL60 for each 115Vac Primary.
In a 220/240Vac supply you still use one CL60 in each 110/120Vac Primary.
i.e. use two CL60 in series to feed the two series connected primaries in a 220/240Vac supply.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th November 2013, 11:55 AM   #2575
In the NPs F5T article is stated:
CLC? Go for it. The thermistor in series with the primary is familiar, and I
recommend the CL30 type. Of course this shows the 120V AC version. For
240V the primary coils are wired in series and the fuse value is halved.
So is there anything what speakes against CL30 from your perspective?
Old 19th November 2013, 11:58 AM   #2576
The cold resistance is too low.
I would guess that 4 in series would be required for effective current limiting during the start up. But then I don't have the money to squander on 4 CL30 for each big transformer.
regards Andrew T.
Old 19th November 2013, 02:55 PM   #2577
4 CL30 or one CL60?
Old 19th November 2013, 03:54 PM   #2578
4 CL30 or 2 CL60
regards Andrew T.
Old 19th November 2013, 06:14 PM   #2579
Originally Posted by Mallard View Post
ZM, thanks for your reply! Is there any rule of thumb how to calculate it?
The only thing I found was: the best way to find correct valus is to simulate it. But I don't have such simulator.
This PSU Simulator is for only one positive rail. But one can play with different configurations and learn :
[url=http://www.duncanamps.com/psud2/]
Old 21st November 2013, 05:07 PM   #2580
dhenryp is offline dhenryp  United States
Default Where to mount PS thermal switch?
I assume the 75 decg C Thermostat Switch on the power into the xformer should be mounted on one of the heatsink. Is that correct?
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 04:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
