F5 Turbo Builders Thread
Old 28th October 2013, 06:46 PM   #2531
6L6 is offline 6L6  United States
6L6's Avatar
You will probably run out of heatsink before you run out of transformer. You may need a fan.
Old 28th October 2013, 07:02 PM   #2532
AudioSan is offline AudioSan  Norway
2A bias and +/-32V rails = 128W dissipation pr ch. the 5U chassis should handle that.
transformerwise. 300VA pr ch will be minimum. so 800VA will for sure do the job
Old 28th October 2013, 07:05 PM   #2533
Mallard is offline Mallard  Germany
Ok, thanks 6L6.
What are the typical bias values other F5T builders?
Most likely I will use the 1Ohm source resistors and try to bias as high as possible by beeing able to touch the heastsink for more than 10 sec.
And will see what the result is.
Old 28th October 2013, 07:34 PM   #2534
6L6's Avatar
I thought we were talking about 2A/device (2A*32=64W, *4 =256W/channel)
Sorry.
Old 28th October 2013, 07:40 PM   #2535
that would have been hot as a dual mono amp 500+W.
Old 28th October 2013, 07:41 PM   #2536
Originally Posted by Mallard View Post
Ok, thanks 6L6.
that WILL result in a burned up amp. it is NOT the heatsinks that limits your bias. it the point where the diodes starts cunducting.
Old 28th October 2013, 11:55 PM   #2537
Sorry AudioSan, I just need to collect what I've learned from you
When I use two 0.68Ohm resistors in parallel and adjust a 340mV bias then I will end up at roughly 2Amps per channel? And in your point of view the 5U chassis can handle that?
it's 2A pr ch. 1A pr device.
dual 0.68ohm resistors is just about right. then he will have 340mV at 2A pr ch.
Old 29th October 2013, 12:16 AM   #2538
correct.
Old 10th November 2013, 04:04 PM   #2539
aft is offline aft  France
Hello,
I'm planning to go for that f5T journey (V2, no cascode, stereo based on last board from diyaudio).
I'm already preparing and have collected usefull informations but still have doubt about matched components.
Can somebody explain :
- What active components need matching whithin a channel ?
- I can remember that the Aleph-x was requiring matched resistors, is that the same here ?
- Is there a need for matching between channels ?
Thanks. Raoul
Old 10th November 2013, 04:13 PM   #2540
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
-if possible , input Jfets need to be of same Idss ; if going to multi output pairs route , all N need to be matched , and all P need to be matched
-if you buy Metal Oxide ones , they're already in enough low tolerance ; if using white ceramic ones (wirewounds) , buy more and measure them (with ccs , measure voltage drop)
-preferably , but not so important
see what's h_a is having to sell
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
