F5 Turbo Builders Thread - Page 250 - diyAudio
Old 16th October 2013, 08:08 PM   #2491
so the left (on the thermo pic) P ch source resistor has a drop of 300mV. then the rigth one must have alot more voltage drop. and the N ch resistors too.
Old 17th October 2013, 01:22 PM   #2492
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
Hi to everybody,
I think that I need some advice about the F5T V2 that I just complete and biased.
2 days ago I installed the trasformer and start the bias following the suggestions found on the forum and in particular the advices from Walter and Buzzforb... slowly! And slowly I reach the 331 mv on both sides in the right channel with the best offset of -0.1.
The same I can't reach for the left channel. I have always a difference of 4.5 mV between P and N and the offset is unstabile. When I reach the 0.0 and I cover the enclosure the offset start to move to - 0.1, -0.2 up to -3.9 (now). The same for the 2 source resistors... the reading increase following the offset. This happen only in the left side while the right is stable.
I suppose that is relevant to the increasing of the temperature but why only for 1 channel? The ampli play music fantastic but I am scare for this channel... may be is normal but some advice should be greatly appreciate.
Many thanks
Enrico
Ps: Just read the meter and the offset is now -5.1. I will reopen and return back to 0.0 as I do already 3 times But I am sure that after half hour it will be the same
Old 17th October 2013, 01:28 PM   #2493
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
-5.1 of what ?
MA , MV , MJ or ........ maybe mV
everything up to +/-50mV is completely OK for home gear , in temp equilibrium
btw. do not compare volatge across Rs of upper and lower part ; choose one side and measure on it ;
so - offset and current on one side is what's needed for proper setting of F5 ( and many other amps)
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 17th October 2013, 01:43 PM   #2494
emyeuoi's Avatar
Thanks Zen... so, nothing to worry about.
I am still curious to understand why is not stable... I will check the offset time to time
Cheers
Old 17th October 2013, 01:45 PM   #2495
Zen Mod's Avatar
well - just for test - cover all air inlets on case , and you'll see it will be more stable
but , do not leave covers for good
it is stable enough and as intended , so do not worry
Old 17th October 2013, 01:50 PM   #2496
emyeuoi's Avatar
ahahaha... Ok thanks!
Old 21st October 2013, 12:25 PM   #2497
KatieandDad's Avatar
Default Thermistors ?
How closely do the thermistors have to be coupled to the Power FETs?
Is this good enough ? I can add a dob of araldite to keep them in place.
Old 21st October 2013, 01:25 PM   #2498
emyeuoi's Avatar
I install the thermistors touching the washers with a little glue.
Old 21st October 2013, 02:31 PM   #2499
rookakoma's Avatar
I'm a fraidy-cat, so I measured 3 different MUR3020 diodes.
I wanted to know the forward voltage drop at 53C, which is the operating temp of my own F5V2 at summer.
Old 21st October 2013, 03:09 PM   #2500
6L6 is offline 6L6  United States
6L6's Avatar
Katie and Dad - That looks fine. Close is good enough. They will still do their job of changing resistance as they warm up.
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2389 9th June 2016 10:07 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
