F5 Turbo Builders Thread - Page 245 - diyAudio
Old 1st October 2013, 01:04 AM   #2441
6L6 is offline 6L6  United States
6L6's Avatar
AudioSan, if you update your BOM, can you make the part numbers match the F5Tv3 schematic from Nelson's original article? The new board's silk numbering matches the v3 schematic.
Old 1st October 2013, 01:07 AM   #2442
abadsantos 7's Avatar
How about options for R5 and R6 if using lower Idss for JFETs. At least for my build with 7.3mA 1K isn't working...I had to change to 2.2K to make it work. Lower it to 1.8K to make the bias adjustment more finer.
If I parallel 2 sets of JFETs (7.3mA) should R5 and R6 should be lower than 1K?
Old 1st October 2013, 01:10 AM   #2443
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
you can parallel 100 of them , then R5 & R6 need to be 100x smaller
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 1st October 2013, 01:13 AM   #2444
Hi Zen,
Got it.
However, since they are preparing the BOM, would it be nice if this kind of note or remarks will be included in the list.
Old 1st October 2013, 01:35 AM   #2445
6L6's Avatar
abadsantos - That kind or remarks would be nice have on the BOM or on it's own document. Would you like to help with it?
Old 1st October 2013, 01:50 AM   #2446
Hi Jim,
Its OK. You may consult others also who use the TOSHIBA FETs, I think they modified R5 and R6 also to a lower value (lower than 1K).
Regards.
Old 1st October 2013, 08:51 AM   #2447
R5/R6 have been discussed in multiple F5 treads. this has been a chalange for many original F5 builders as wel. there will be some that need to go a little higher on R5/R6, but there is no standar.
Old 1st October 2013, 08:53 AM   #2448
oh. there is New component markings on the boards?
Old 1st October 2013, 01:50 PM   #2449
here you go look over it and make sure it is correct.
Old 2nd October 2013, 06:58 AM   #2450
Audiosan
The terminal blocks have gone to allow multiple ground connections on the Front End board and multiple output connections on the N & P Channel boards.
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
