F5 Turbo Builders Thread - Page 242 - diyAudio
Old 23rd September 2013, 11:53 AM   #2411
Banned
To be honest, I don't recall. I don't have the kit nearby, as I said: this is a long term project. But I guess he delivered the parts mentioned in the BOM
http://www.fetaudio.com/wp-content/u...-BOM-Cost2.pdf
Old 27th September 2013, 02:00 PM   #2412
6L6 is offline 6L6  United States
6L6's Avatar
A request for assistance -
Would anybody be willing to make a BOM for the F5Tv2 and F5Tv3? Preferably with Mouser part numbers? The community would be very grateful.
Old 27th September 2013, 03:01 PM   #2413
I'm happy to have a bash
Old 27th September 2013, 06:38 PM   #2414
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
now that we have JFETS in the store, could someone comment on what grades would work best? I think "Papa" mentioned "B and C" but aren't sure I remember correctly.
http://www.diyaudio.com/store/parts/...o-92-jfet.html
There are links to their spec sheets
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio [/B]
Old 27th September 2013, 07:04 PM   #2415
henryve is offline henryve  South Africa
henryve's Avatar
For the F5 I would expect the B to be the best fit.
Old 29th September 2013, 02:49 AM   #2416
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Folks:
Your advice on the positioning of the toroid and power supply pcb would be appreciated. I'm building several F5T amps with friends. We've purchased 5U/400mm "big amp" enclosures from the Store, 1000 VA SumR toroids and are using large power supply pcbs supplied by Buzzforb. My question: is it better to (a) center the toroid in the chassis and mount the power supply pcb on standoffs directly above the toroid or (b) follow the more traditional approach of mounting the toroid towards the front of the enclosure and the power supply pcb on the floor towards the rear? It seems to me that (a) minimizes any blocking of the vents on the bottom plate and would maximize airflow through the chassis around the toroid/ps pcb stack, whereas (b) maximizes vertical space above both the toroid and ps pcb at the possible expense of impeding air flow from below.
As newbies, we're open to either approach and assume that someone has exhaustively assessed both options. And if not, does anyone have a considered opinion?
Scott
Good decisions are derived from experience; experience is derived from bad decisions.
Old 29th September 2013, 03:47 AM   #2417
6L6's Avatar
Scott - I would do whatever will place the PSU board closest to the amp boards. In the 5U, that will likely mean the toroid towards the front and PSU towards the rear, however you have lots of flexibility in heighth because the 5U is so tall.
It's going to come down to wether or not you can mount the PSU and toroid on the floor of the amp, in a way you like.
Old 29th September 2013, 08:21 PM   #2418
While on the topic of the 5U case (which I am also using) and its floor space for power supply doo dads, I have a question. My previous F-5 build has a floor pan made from 1/8 inch 6061 aluminum, and I mounted the POWER SUPPLY diodes (MUR) to the floor pan of the amp as heatsinking. With the 5U case, this would mean attaching them to that perforated metal floor....is this sufficient heatsink for those MUR PS diodes? (As supplied from Buzzs group buy kit)
Thanks,
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 29th September 2013, 08:28 PM   #2419
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
it is
don't forget insulators , though
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 29th September 2013, 09:56 PM   #2420
6L6's Avatar
^^^ What he said.
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 04:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
