F5 Turbo Builders Thread - Page 240 - diyAudio
Old 17th September 2013, 11:50 PM   #2391
KatieandDad's Avatar
I've never had any problems with E-Bay, I've been careful though. The only fakes that I bought were from a reputable supplier.
Old 17th September 2013, 11:52 PM   #2392
How do I contact h_a or spencer ?
Old 17th September 2013, 11:58 PM   #2393
billyk is offline billyk  United States
billyk's Avatar
eBay, just say no! Don't waste you money!
Spencer sells the the 170 and 74 and buzzforb has outputs. h_a sells a whole kit. All are members and all have the real deal.
Edit: here is a link to h_a's post F5 amp transistor kit
Old 18th September 2013, 12:10 AM   #2394
I've been trying to contact H-A but his e-mail has gone dead.
Old 18th September 2013, 12:15 AM   #2395
billyk's Avatar
Spencer's site: FET Audio | Hi-End Audio ProjectsStore | FET Audio
Old 18th September 2013, 12:16 AM   #2396
6L6 is offline 6L6  United States
6L6's Avatar
Katie and Dad - check your PM.
Old 20th September 2013, 12:51 PM   #2397
gabsta is offline gabsta  United Kingdom
Ah ok audiosan if you ever want highest quality audio leads for any of you gear I can put you in contact no doubt.
His father in law has gear worth over 100k and my cousin has made him leads which are way better than ones he was using
The sinks I can't see me changing but maybe I could rotate the boards but iam not sure if that would make any difference. What is the voltage you should set bias too ? As my other friend who is going to help me says basic multimeter wouldn't be good enough to set at 0.03 volts whih I think is what riki said somewhere around that but prob remembering wrong
Old 20th September 2013, 01:50 PM   #2398
bias is set over 0.5ohm resistors. so for 0.9A bias pr device. you chould read 0.45V over the source resistor. but you can't get it that high. after passing 0.7A pr device (0.35V) you need to be carefull and watch the bias. as the sinks get hotter, the diodes conducts earlier. you can take out the diodes for now. that will make it easier for you to get it up and running.
Old 20th September 2013, 02:09 PM   #2399
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
since the F5Turbo is based on the standard F5, I suppose bias setting issues/problems are more less the same
its well know that bias can be tricky
but not so difficult if you know how it works
do it wrong, and it could be bye bye amp
is it the same as with the F5 ?
(if so, maybe there is much more info to find in F5 threads)
I suggest to also try and use forum search function
sometimes we know very little, and sometimes we know too much
Old 20th September 2013, 02:25 PM   #2400
buzzforb's Avatar
Yes, bias is same as f5. It is best to set bias low and then trim offset. After doing so yuo can then bring bias up slowly adjusting both pots together and watching offset.
...Shape the sound , Man!
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 04:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
