F5 Turbo Builders Thread - Page 228 - diyAudio
Old 9th July 2013, 11:17 PM   #2271
buzzforb's Avatar
Holy sh^t. Andrew agreed with me. Beulah land, here I come.
...Shape the sound , Man!
Old 10th July 2013, 06:37 PM   #2272
If any one posts the truth, then surely it follows that at least one other Member will agree.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 17th July 2013, 09:18 PM   #2273
nashbap is offline nashbap  United States
Originally Posted by WalterW View Post
Making some progress...
I thought posting some pictures will be nice.
I'm rebuilding my F5Tv2 to a v3.
One channel is done, think I test it first, before buiding the next channel. Curious if it will be stable with the larger output stage.
I'll test it today, hope I don't destroy it
Made some improvements too.
-Used Kerafol 86/82 red for the outputs and diodes. On the first pic you can see it's rather fragile, can't be used twice. I mounted the outputs for a test with M4 bolds with washer, as tight as possible, and it gives too much pressure in the area of the M4 so it destroys the Kerafol.
So I decided to make a clamping bar of 4 mm steel just for the outputs. See pictures.
Hope the thermal coupling gets better. Will post the results.
- Coupled the Jfets with some copper and thermal glue.
- I glued the new (better) thermistors to the outputs. I have good experience with that, with my standard F5.
- Replaced the 10 Ohm JFet source resistors for Dale CMF55's.
- made the connection to the PSU with faston connectors, so it's easier to disassemble.
- Upgraded the outputs source resistors to 10 Watt with two paralled MPC74 0.47 Ohm resistors. Looks nicer when the whole PCB is filled with components...
- upgraded some cabling with thicker 6mm cable. And for the input no more fragile coax, but twisted signalwire. Like Pa does...
Oh, and I build a DC-filter ( schematic of Rod Elliot) for the mains, see picture, and now all mechanical hum of the big toroids is gone !
Walter, your work looks brilliant. Love the way you have placed the caps in close proximity to the amp board. Any further progress? What boards are you using for the amp and the caps? What transformer output voltage? Why the two paralled 0.47 ohm resistors instead of the 1ohm suggested? Thanks.
Old 18th July 2013, 07:17 PM   #2274
WalterW is offline WalterW  Netherlands
Thanks nashbap,
I posted the last pictures of my finished f5T v3 here:
Pictures of your diy Pass amplifier
I used the Teabag PSU and AMP boards, he is a member on this forum. So easy to find.
Transformers are 2 x Amplimo 2x25V 2 x 12,5 Ampere. I'm using matched Toshiba 2sk1530 / 2sj201 for output devices and those devices need around 0,22 Ohm for source-resistors. So 2x 0,47 Ohm paralleled.
Walter
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 18th July 2013, 07:28 PM   #2275
[QUOTE=nashbap;3565015]Walter, Any further progress? QUOTE]
Haha, bit OT but making progress with this:
drivers: Vifa NE123, Vifa NE265 and Scanspeak Illuminator D3004/66200
Old 20th July 2013, 10:52 AM   #2276
Spectacle style bracing give a lot more glue area than X style.
regards Andrew T.
Old 20th July 2013, 11:30 AM   #2277
Hi Andrew, my English isn't that good... what do you mean with 'spectacle style bracing'?
Old 21st July 2013, 07:47 AM   #2278
A plate across the whole cross-section of the box with two big holes cut out of it to look like spectacles.
regards Andrew T.
Old 21st July 2013, 03:01 PM   #2279
henryve is offline henryve  South Africa
henryve's Avatar
Figure 8 braces.
Old 1st August 2013, 07:12 PM   #2280
duder1982's Avatar
Everybody must have gotten parts to build their amps, kind of quite around here lately. Well at least this thread.
If I cant build it or fix it I really dont want it.
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
