F5 Turbo Builders Thread
Old 26th June 2013, 01:14 PM   #2161
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Buy a PSU board from TeaBag. Simplify the PSU section, eliminating most of your internal wiring and complication. I have used this exact setup that I am recommending and it is no harder than an F5 to build. You must also make sure you haev valid components. This may have been discussed, but needs to be reiterated. I would only buy Jfets from one source. Spencer. Output fets are easier to come by and should not be a problem. You can do this, i tihnk you are just overcomplicating the process with the custom PSU, which also makes it difficult to help,as we are not working with a known standard.
...Shape the sound , Man!
Old 26th June 2013, 01:16 PM   #2162
billyk is offline billyk  United States
billyk's Avatar
2nd the motion on the Teabag PSU board.
Old 26th June 2013, 01:18 PM   #2163
6L6 is offline 6L6  United States
6L6's Avatar
I agree as well - get the PCB and carry on.
Old 26th June 2013, 02:48 PM   #2164
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
It does look good. We really like the way you have the gain board between the output boards and are hoping to have holes in the new boards that will allow us to make that easy for those with the pre-drilled (UMS) heatsinks to do the same.
Originally Posted by Rixsta View Post
Considering im no electrician but that its just a fun hobby I think I Did pretty well
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 26th June 2013, 10:31 PM   #2165
Rixsta is offline Rixsta  United Kingdom
Cheers, well Ive been offered more money possibly will continue
So Im trying to find where those PSU boards are, guess ill message him direct.
BTW : when the amp blew i turned it on once and heard a tightening sound, then turned it off then back on same tightening sound then it sounded like it just snapped and saw some smoke, not on resistors anywhere it seems but from the Mosfets which all 4 seem dead in one go.
I understand you can tell whats going on better if Im using those Tea bags boards, cheers
www.rikibuckingham.com...
Old 30th June 2013, 06:45 AM   #2166
abadsantos 7 is offline abadsantos 7  Philippines
abadsantos 7's Avatar
Would like to inquire what is the normal DC offset for F5T V2 at speaker terminal at cold start?
Cheers.
Old 30th June 2013, 09:06 AM   #2167
R.I.P.
different from the fully warmed up offset !
regards Andrew T.
Old 30th June 2013, 11:02 AM   #2168
The amp would be idle overnight then upon turning on the power button (via soft start), what DC offset voltage max is expected?
Old 30th June 2013, 11:38 AM   #2169
buzzforb's Avatar
Is it causing a problem?
Old 30th June 2013, 12:21 PM   #2170
Hi Buzz,
I dont know if its a problem. Still on experimental mode.
Turn On - I have about 50mv DC offset then after awhile it will drop to 30mv then after 5 to 10min will be stable on +/-1mv.
Turn off - I will have a DC offset swing of about 400mv at the speaker terminal.
Im using jfets from Spencer at 7.3ma. Im not yet using the FETS from yours.
My bad, I was not able to buy some extra Fets from you for experiment purposes.
Just trying to understand first the behavior at the terminal that will not damage my speaker in future.
Cheers.
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
