F5 Turbo Builders Thread
Old 21st June 2013, 12:04 PM   #2141
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Some would argue that it is all speaker dependant. I have found there is definitely a point where more available power does not improve the sound any and you begin to look to other areas for change/adjustment. THat being siad, for most folks using multiways speakers, a 100W Class A amp is not too much, especially when considering the transient needs of such setups. I think it large comes down to ease of presentation of music. Once you get to a point where you do not feel increasing the power is changing this, you probably are in a good spot.
...Shape the sound , Man!
Old 21st June 2013, 12:19 PM   #2142
R.I.P.
I suspect that with most speakers and most listening conditions in most houses, that peak output voltage is not a problem. I think we may more often distort the waveform due to current clipping, particularly if our peak to average overhead is maintained around the 20dB range.
50W into 8ohms, but feeding a 4ohms speaker, can require transient currents approaching 30Apk. Not many 50W amplifiers can maintain drive voltage while delivering 30Apk. That's what I see as the problem at "sensible" levels.
Playing loud and well into voltage clipping is a different ball game.
regards Andrew T.
Old 21st June 2013, 12:35 PM   #2143
buzzforb's Avatar
IN my new speakers setup, 10W will deliver 110 dB
Old 21st June 2013, 12:39 PM   #2144
AudioSan is offline AudioSan  Norway
Buzz. i need 100W to get to the same point
but thats the way it has to be when i can't stand horns
Old 21st June 2013, 12:44 PM   #2145
buzzforb's Avatar
I may not like them either, dunno yet, but there is something attractive about having that kinda dynamic swing available. I am looking forward to your build
Old 21st June 2013, 12:54 PM   #2146
henryve is offline henryve  South Africa
henryve's Avatar
I currently have standard 2-way floorstanders that is rated at 89db. My KSA50 can drive those at levels that hurts my ears. I however have been eyeing the Troels Gravesen DTQWT Mark II design. My room is 5 by 4 meters.
Sorry for OT.
Old 21st June 2013, 05:30 PM   #2147
Rixsta is offline Rixsta  United Kingdom
Would It be silly to ask you henryve to compare your KSA50 to the F5t
Not with what sounds better or worse but the differences ?
www.rikibuckingham.com...
Old 21st June 2013, 06:06 PM   #2148
Although interested in your listening Impressions.
Old 21st June 2013, 06:09 PM   #2149
henryve's Avatar
Still need to get the transformer and heatsinks for the F5T, so it might be a while.
Old 22nd June 2013, 01:56 AM   #2150
I see thanks, Im almost complete with my build but as its not being built for me had to rush, Its much nicer taking a little bit of time!
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
