Old 9th May 2012, 06:07 PM   #201
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
in usual/common Papamp , pretty much everything is on same temperature ......... in other words - in 10C window
so , just clamp them to main hs
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 9th May 2012, 06:22 PM   #202
yes. i had a look at the diode data sheet. and the differece is marginal.
so there is no point in using external heatsinks.
as long as one is not going to push the bias to the limit
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 9th May 2012, 06:25 PM   #203
Zen Mod's Avatar
same goal for every iteration ......... keep those heatsinks at 55C , max .....
no brainer .......... then .
Old 9th May 2012, 06:29 PM   #204
i was thinking of bias and the point the diodes starts cunducting
Vivaldi8 speakers
Old 9th May 2012, 06:32 PM   #205
buzzforb's Avatar
Heatsink or no heatsink is solved or irrlelevant..... Just make sure you got an adequate heatsink. Here is my question. PLease explain this statement and how it relates to the ouput power of the amp.
"What if you remove the Source resistance altogether?
First off, you get the 44 amps. In addition, with Fets you get an output stage
that will deliver more Class A power at a given bias figure due to the square
law character of the Fets."
"The result is that the amplifier can now deliver 38 amp peaks"
First statement seems to suggest a cheat for more pure Class A, but the second seems to slip into the A/B category. Funny that he has addressed this very topic in another article, but equally funny that he has chosen to take his Pass amps in the dircection of more true Class A power.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 9th May 2012, 06:33 PM   #206
Zen Mod's Avatar
@AudioSan
another angle of same picture
Old 9th May 2012, 06:37 PM   #207
buzzforb's Avatar
So Class A is still Class A and diodes just allow full acces to given fets abilities, even if it is of a hybrid nature. Funny, all this talk of power, I was uncomfortable listening to single pair version. Of course i do not have proper multiway speaker and lsiten to silly FR stuff with woofers.
Originally Posted by gl View Post
Buzz,
Which Maggie do you have?
I'm using 3.6's driven by AX100J's. Although I really like the sound I'm getting, you guys are starting to make me wonder, in an expensive kind of way, how an F5T would compare.
Let me say that I appreciate the encouraging way you all are sharing your results. Great work!
Graeme
1.6, but not mine.
Old 9th May 2012, 06:38 PM   #208
Zen Mod's Avatar
Originally Posted by buzzforb View Post
buzz
context is very important .
just because of disregarding that , every F5T thread is at least 65% nothing more than noise
Papa was talking there about more class A in heavy (low ohmic) load
edit :
if one is not in need for hefty Turbo cojones , it's insane to build it
Old 9th May 2012, 06:41 PM   #209
gl is offline gl  United States
I don't recollect hearing about these diodes being used in any Pass main line product. But then they haven't been including the "Fun Hardware Facts" section in the manuals for a long time. So who knows.
That being said the diode idea is particularly clever and is a real plus for smaller amps that need the ability to produce extreme current peaks.
Graeme
Old 9th May 2012, 06:46 PM   #210
Zen Mod's Avatar
yup
that's the very jewel of F5T article/project
everything else is "just" upping [voltage/bias/number of outputs] tutorial
Originally Posted by Zen Mod View Post
I can't tell that entire article is revelation to me ( from several reasons ) , but I can tell that devil is in diode detail ......
so - I'm Happy ZM Camper
F5 Turbo Circuit Boards chchyong89 Pass Labs 2131 23rd May 2013 10:36 PM
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
B1 builders thread Bas Horneman Pass Labs 688 27th February 2013 11:15 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2013 diyAudio
