F5 Turbo Builders Thread
Old 19th February 2012, 11:10 PM   #11
nrg2009 is offline nrg2009  United States
This is big time, wow pretty nuts, but awesome.
Old 19th February 2012, 11:41 PM   #12
Bksabath is offline Bksabath  United Kingdom
Banned
with 4 mosfets on each you may need to paralel the imput J fets
What bias current you planning on ?
Papa said mentioned the hiher the beter they sound
the traffo and I am most probably wrong shuld give you about 11A (750 VA / 70 V )
1 A bias wuld dissipate 48W device well in the TO3P specs and the 4 amps is again prety close to Papa recomendation for the trafos
You be looking at about 380W dissipation on the sinks
I got same 300 X 400 X 83 (12 x 16 x 8 ) and I recon they are good enoug for 250 W
With the rails split between the 2 sinks that sems to be prety much a good fit.
Sems like you done a fair bit of thinking about it already
Old 20th February 2012, 12:07 AM   #13
ungie is offline ungie  Canada
From Papa:
"The V3 schematic shows 4 pairs of output devices. Realistically you can
expect to get more than 100 watts rms Class A into 8 ohms and 200 watts
Class AB into 4 ohms. You are going to need some serious heat sinking, and
I suggest that the power supply of V2 would be appropriate for a single
channel. Peak output currents of 70 amps are expected but not guaranteed."
The cascoding of the input Jfets solves the challenge of higher rail voltages and is suitable for 4 pairs of output devices. As for the efficacy of the heatsinks I have, this will be determined once I get a board layout completed, have PCBs fabricated, and actually build one!
Old 20th February 2012, 12:30 AM   #14
Banned
Tanks for that
and have a nice day
Old 20th February 2012, 01:22 AM   #15
camshaft is offline camshaft  United States
I also have 2 pairs of the 11" R-theta heatsinks and am hoping to do something along the lines of 50W per channel balanced monoblocks per the V3 layout.
For you guys who are fans of big PS capacitance, have you done blind tests to see if you can tell the difference? Say between the 100K uF on the pass circuit vs something like 200K uF? Or lower ESR caps vs higher ESR? I've often wondered how much of it is simply for the bad-a** factor, and although better in theory, isn't audible.
Austin
Old 20th February 2012, 02:09 AM   #16
Banned
I cold not hear much difference with 100 150 and 200 K rails apart from riple reduction that cames with CRCRC instead of CRC
It wuld be much different if the capacitance was low for the load
say going from 20mU to 40mU as 20 will be definetly to low and 40 border line.
about esr I got a mix of eswa 63 V (cheap) and Rifa 40 V (Rifa) so cant realy say
If I build the 48 V the Rifa are going in the bin (sinfull waste)
I shuld have got 63 V Rifa to start with
With the caps is beter if you get a few hi voltagge ones and add when possible
insted of loads of low voltagge and have no use for them later.
If you need just a 50 w even standard balanced F5 will do
Not many have eard the turbo so far so you may compromise sound quality for power
How did you decide on the 50 W figure?
Old 20th February 2012, 02:41 AM   #17
I always struggle with finding the right enclosure/sink. It would be great to have some guidance on where to get affordable sinks/enclosures that are sized for the job. Someone brought up that they got good sinks from Antek on their ebay store. I like Antek toroids, so that might be a good option.
Old 20th February 2012, 03:26 AM   #18
Oh not for any rational scientific reason - partly because I already have enough heatsinking for 50wpc, and 25wpc monoblocks with that much heatsinking feels a bit underwhelming. Also, I'll be using them on my zaph sr71 speakers, which aren't the most efficient. My cheap 15W T-amp is fine for now in a small room but I'd feel better with the head room. I have been watching the F5X threads, but I'm guessing the F5T will start gaining more popularity and support over time, as I won't get around to starting assembly for another half a year or so.
Old 20th February 2012, 03:42 AM   #19
Banned
Scientific reasons and math escape me (or me try to escape)
Yeah I wan't more power to.
There is an easy way to find out how much you need
Set the volume to party time (Uny dorm party time maybe not)
and then play low frequency sine at -12 dB mesure up with DM and multiply by 4
that is the max voltagge you will ask out of the amp F5 clip at 2 V from rails so a bit spare on top of that bit of mat give you the minimum rails voltagge from that the rest is post 12 but I am shure you have read Papa paper and don't need patronising old git to go over it a different way.
Pano started a tread about it on multy way and first few post are worth reading.
If you are planning to wait for 6 months by then F6 shuld be out and then it all change
If you got spare bits start with F5 well worth it.
F5turbo sound good on paper for now but does it sound better than F5 ?
Head room is big thing especialy if you listen to Classical
Not so big an issue with modern CD
Old 20th February 2012, 03:47 AM   #20
Banned
If you are after same monster sinks gogle up Gorini SRL
They do up to 400 mm wide and can weld 2 or more togheter and cut to any leght
Price put to shame the rest but P&P is the killer
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
