F5 Turbo Builders Thread - Page 193 - diyAudio
Old 27th May 2013, 04:28 PM   #1921
WalterW is offline WalterW  Netherlands
Originally Posted by 6L6 View Post
BuzzMod is saying 'Graetz' like ZenMod. LOL!!
(Graetz = Diode Bridge)
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 27th May 2013, 04:31 PM   #1922
Rixsta is offline Rixsta  United Kingdom
Send a message via Skype™ to Rixsta
Im going to Go foreward and wire it up later anyway, and apply a small AC voltage just to test. and insulate diodes of corse!
The only thing I need to actualy know is if the ground Points in that schematic go to Chassis, or if only the ground from IEC socket goes to Chassis.
www.rikibuckingham.com... DIY=Zen V4, Zen-lightenment‎, Jean Hiraga 20w,
ACA, F5, F5T, Audio Freaks Club
Old 27th May 2013, 04:49 PM   #1923
buzzforb's Avatar
You are using a single Graetz/bridge. Many are using dual Graetz. Yours will work fine if wired properly, but will not give same performance as dual bridge. F5 Manual, pg 18, has dual bridge setup.
http://www.firstwatt.com/pdf/prod_f5_man.pdf
From Pearl II article, by Wayne Colbourn
"First, there are two rectifier bridges instead of the usual one. We do this because the positive rail will be sourcing more current to the circuit than the negative, and in this circumstance dual rectifiers will avoid the transformer noise which often accompanies this."
IEC oulet goes directly to chassis and psu is connected to earth/chassis through a thermistor/bridge combo, which lifts that point a diode drop above ground to further help with noise.
...Shape the sound , Man!
Old 27th May 2013, 05:10 PM   #1924
bnorrish's Avatar
Haha. I had to Google "Graetz" back when I was reading the Pumpkin cookbook.
Old 27th May 2013, 05:20 PM   #1925
buzzforb's Avatar
THats how we learn, one little bit at a time. Sooner or later, we might actually know something, although I have not arrived at that point yet Still close my eyes when I plug in my amps.
Old 27th May 2013, 05:46 PM   #1926
Ok I like your attitude, i figured 2 diodes was equal to 1 Graetz and im using 4.
but yes page 11 of www.firstwatt.com/pdf/art_f5_turbo.pdf I have copied Exactly. But I may Swap to using the 2x 200v 35A, bridge rectifiers I have Or order another 4 Diodes to make dual Graetz.
But let me clarify lol, That page 11 is showing 4 actual Diodes ?
Old 27th May 2013, 05:50 PM   #1927
buzzforb's Avatar
Yes. But many thought that it seemed odd that he stepped back from dual Graetz in F5 to a single, in what was a more powerful amp. He has been known to cut and paste his articles. As i said, if you wired properly for single bridge, then you are fine. You may find that the traces on the veraboard are being pushed a little in this instance, but should be ok for short term solution.
Old 27th May 2013, 05:56 PM   #1928
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
In the medical field on this side, one needs to learn loads of Latin(Greek) names for anatomy & physiology.
Across the pond(s), many of those words are integral parts of the American/English language.
Lose a little, gain a little.
(Graetz is the standard on these shores. Think Zzz likes Graetz more, than other way round)
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 27th May 2013, 06:00 PM   #1929
Thanks for your help I agree that is a bit odd, i had just figured those MUR were more powerful originally but now I see. But never expected the amp to pull more from the positive side than the negative as you would have thought it would be symmetrical but I guess we are not talking logic here lol
The veraboard i have doubled up using a few tracks as one but may add wire to thicken connections OR. Buy the official Diyaudio Power supply boards, If i can get 20 caps on 2 of them! they do look rather well done.
Old 27th May 2013, 06:05 PM   #1930
the difference between Diode bridge/rectifier and Greatz is as big as between
swedes and turnips lol
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
