F5 Turbo Builders Thread
Old 14th May 2013, 07:00 PM   #1851
Rixsta is offline Rixsta  United Kingdom
Yes, I remember reading you saying this on another post somewhere.
Thanks Im thinking of going this way with good relays OR just putting appropriate fuses on the secondary AC or after Caps DC ?
Im Presuming with the right fuses, they would blow fairly fast and the speaker may see DC for a second or two.
Atleast fuses are some form of protection without having to worry about sound quality issues.
www.rikibuckingham.com...
Old 15th May 2013, 02:20 PM   #1852
WalterW is offline WalterW  Netherlands
Two questions:
- When I power up my new F5Turbo v2 it consumes around 300 Watt total and after an hour or so they stabilize around 350 Watt ( that is the bias I set them to when they were hot). Is this a too big difference ?
The R11 and R12 resistors which are in series with the NTCs are already lowered to 1k21 instead of 2k2. Should I lower them further or even short them?
- One transformer starts sometimes humming for a few seconds, or a minute and then the hum dissapears slowly. With a cold and warm amp, very unpredictable... The amps bias and powerconsumption does not change when humming.
I noticed this behaviour already testing the transformers without load.
What is the reason of this? What can be done?
Walter
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 15th May 2013, 02:25 PM   #1853
6L6 is offline 6L6  United States
6L6's Avatar
Your power consumption seems normal.
The important question is what is your measured cold bias and what does it change into when it's warm?
Old 15th May 2013, 02:40 PM   #1854
ijscobar is offline ijscobar  Netherlands
Banned
Walter, what kind/brand/rating transformers are you using?
Old 15th May 2013, 03:06 PM   #1855
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
dc in mains?
" If you're going throu hell, keep going"
Old 15th May 2013, 03:47 PM   #1856
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
F5 Turbo Builders Thread Send a message via Yahoo to vdi_nenna
Default Transformer Rating
When building the v3, it's recommended to use a transformer with twice the rated VA. I have two Antek AS-4218 rated at 400v or approx. 11A each.
With secondaries in serial for 36v, will the secondaries deliver half the current?
Will the transfos be enough for mono block v3 F5? Would 5-6 amps be enough to drive 1 channel to 100w?
Thanks,
Vince
I build, therefore I am.
Old 15th May 2013, 04:01 PM   #1857
Two new Amplimo's 98016 : 625VA, 2 x 25V, 2 x 12.5 A, made in UK.
Total of 1.25 KVA for 320 Watt class A dissipation.
So 4 times the dissipation, which is good according to Papa
Old 15th May 2013, 06:04 PM   #1858
dc in mains?
DC in the 230 Volts? Is that possible?
Old 15th May 2013, 06:17 PM   #1859
diy newbie
oiphy's Avatar
Default afraid so.
yep..... and it saturates the trafo so it starts humming..
there's an easy fix with two diodes and two caps I believe... edit : AndrewT posted a link to it a while ago...
edit: http://www.federalpacific.com/litera...ormernoise.pdf maybe some help here
Old 15th May 2013, 06:20 PM   #1860
Hi 6L6,
I measured cold exact 0.2 volts over the 0,1 Ohm resistor in each PSU rail.
So cold 2.0 Ampere = 1.0 Ampere per MOSFET.
Over the P channel 0.22 Ohm sourceresistors I measured 0.217 V and 0.212 Volt, so that's indeed around 1 Ampere / MOSFET.
When the Amp is hot, I measure 0.252 Volts over the 0.1 Ohm PSU resistor, so my beloved 2.5 A per rail. The 0.268 V and 0.262 Volts over the sourceresistors confirm this. Around 1,25 Amp / MOSFET.
So that's what the bias changes from 20 degrees Celsius to 52 degrees Celsius.
Is that too much?
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
