F5 Turbo Builders Thread F5 Turbo Builders Thread - Page 182 - diyAudio
Old 23rd April 2013, 03:37 PM   #1811
WalterW is offline WalterW  Netherlands
I don't understand what is not ideal? Should the grounds of both PSU's be closer together? What if I connect both grounds with very thick wire or copperstrips?
How do I get it ideal?
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6
Old 23rd April 2013, 03:42 PM   #1812
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Jumper wire is not ideal, but i think you are at point of diminishing returns. If it doesnt hum, who cares.
...Shape the sound , Man!
Old 23rd April 2013, 03:46 PM   #1813
Ok, I'll make the jumper wire massive then...
Old 24th April 2013, 02:16 AM   #1814
omishra is offline omishra  India
When to connect both grounds together? (Same transformer)
IMO if you have derived both channel PS from same secondaries of one transformer then you are going to get one ground loop when both inputs grounds are connected. Then you need to connect both grounds together at the output of PS. This case applies mostly for floating ground not necessarily transformer CT as ground. But ground from same transformer CT may also need this.
If its required to connect both grounds together then I suggest using thickest copper wire (at least 4X of transformer lead thickness).
When its not required?
While both channel PS are distinct, I mean two transformers or different secondaries, then its not required. Here both grounds are separate. It does not matter if they are connected together. While connecting both of these (floating?) grounds one must use ground isolaters to keep them distinct.
Old 30th April 2013, 08:16 AM   #1815
NicMac is offline NicMac  Italy
NicMac's Avatar
Default 2SK1530 and 2SJ201 for F5 and F5 Turbo
I would like to alert F5 Turbo builders that I have just put up for sale in this thread a significant number of the very good Toshiba 2SK1530 and 2SJ201 MOSFETs perfectly suited for the F5 and F5 Turbo variants.
Here is what Mr. Pass has to say about these Mosfets in the F5 Turbo manual:
"A number of DIYers have speculated on or even tried the Toshiba 2SK1530 and 2SJ201 Mosfets. These are really nice (discontinued) audio transistors and are very fine for F5's, but keep in mind that with a 12 amp rating they have a smaller maximum current than the Fairchield parts. This will not prevent them from sounding very good, however, and I do recommend them in general."
The quality of device matching is extraordinary (@ operating conditions) and I have set the price so that everybody should be able to enjoy these fantastic Mosfets without breaking the bank.
Enjoy
Old 30th April 2013, 09:45 AM   #1816
emyeuoi is offline emyeuoi  Italy
emyeuoi's Avatar
Thanks Nic!
You have PM
Ciaooo
Old 30th April 2013, 09:21 PM   #1817
alazira is offline alazira  United States
alazira's Avatar
Enjoy
Has anyone built a F5T with the toshibas? I was wondering if the source resistance or bias needs to be changed.
Old 30th April 2013, 09:44 PM   #1818
henryve is offline henryve  South Africa
henryve's Avatar
I have not finished mine yet, but plan on using those Toshibas. I am going to use 1.2k resistors for R11, R12 for the lower Vgs of the Toshiba devices. That is all that I am aware of.
Old 30th April 2013, 09:49 PM   #1819
NicMac's Avatar
Nelson say: "or even tried the Toshiba 2SK1530 and 2SJ201 Mosfets", but I guess this refers to the F5/F5X and not the F5 Turbo.
Nevertheless, I see his comment as a warm invitation to try
I don't need the power of the F5 Turbo, but I do hope that the (very) low cost of the Toshiba FETs I'm offering will inspire somebody to try and report back.
I guess one would lean towards more output devices and lower bias in the case of the Toshiba's to keep current/fet lower, but that is just my unqualified guess
Old 30th April 2013, 10:11 PM   #1820
evanc is offline evanc  United States
Location: New Jersey. About 1 hour from NYC and 1 min. from the beach
OK so I didn't build it , but thanks to the extreme generosity of a fellow member I have been listening to this for a few hours. Fairchild outputs. I simply put the boards in place of my f5 boards, set the bias and sat back to listen. WOW... At first I had the bias set very conservatively, but at .5 amp per device this thing really sings. As the name implies it sounds like my f5 only on steroids. I will be adding the diodes to this build tomorrow and will report any difference. As it stands, after running a few hours, the output fets seem to have settled at 56c and the sinks are 48c. I attached some pics...don't laugh..
Evan
55 47
http://www.evancotler.com
F5 Turbo Builders ThreadHide this!Advertise here!
F5 Turbo Circuit Boards chchyong89 Pass Labs 2398 7th July 2017 10:16 PM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
