F5 Turbo Builders Thread
Old 1st April 2013, 04:12 AM   #1711
Bksabath is offline Bksabath  United Kingdom
Banned
Originally Posted by Jallhalla View Post
Could I build a mild v2 turbo by using two pairs of mosfets and diodes over the resistors, but using only the original f5 18v psu transformer? Im building an f5 now, and Im already considering how to improve it.
If Im thinking correctly this would not give me an improvement in watts, but could make it a lot more powerful at difficuld loads?
Thanks for any thoughts on this!
As I understand the Turbo part is carried out by the diodes, thet kik in at hi voltagge so why do bother for 18 V trafos?
I am running twins on 26 V rails on 4 Homs speakers (nasty ones) and it is prety good.
IMO First decide what power you realy need
then build stock version to get taste of it
then based on that you are prety free to get up and up but ditch the 18 V traffo
About the considering to improve the F5 see abowe< build stock first>
PS the J fets can take up to 35 V rails before cascoding but cascoding only add further bonuses and the current limiters are not realy needed but get same speaker protection duda
Old 1st April 2013, 10:06 AM   #1712
SteveHolt is offline SteveHolt  United Kingdom
Default F5, V1 PSU problem, getting 70V !
Hello
Turned on psu and amp circuits yesterday to start final set up and the little J74 / Q2 smoked, only on the left channel.
And for some reason the output from the PSU had doubled from 35 previously to 70v. I know that the little transistors have a breakdown point of 60v
Today I disconnected all 6 leads from the PSU to the amp boards. My simple test shows that I am getting +35 and -35 from the bridge rectifiers. Next test; positive lead from meter on + of PSU, and negative on PSU gives +70vdc, however placing black lead from meter on PSU GND result is 35vdc. What I have done wrong??
Old 1st April 2013, 10:34 AM   #1713
Marra is offline Marra  United Kingdom
I f I read correctly you're p/s sounds ok.With the leads across plus to neg will give 70vdc.Connect the black lead to the centre connection between the caps and move the red lead from pos +35v to neg will give -35 hence your 70v across +-. As to the smoking jfet some one with more knowledge will no doubt chip in.Good look.
Old 1st April 2013, 10:39 AM   #1714
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Pics are thee best way to help.
...Shape the sound , Man!
Old 1st April 2013, 10:50 AM   #1715
the diodes kick in when the output current demand rises too high, as determined by the voltage drop across the source resistor.
The diodes make more current available to the load by bypassing the Source Resistor.
The diodes help to reduce the voltage lost across the Source Resistor when high currents are demanded.
It does not matter whether a the PSU is +-20Vdc or +-50Vdc, the diodes turn on at high current demand.
regards Andrew T.
Old 1st April 2013, 10:58 AM   #1716
labaffegaston is offline labaffegaston  France
hello
this my first post on diyAudio,
i hope my english level is good for tey to build an F5T.
i have already build uP and ugs .
i see this kit :
F5T Turbo Power Amplifier kit for sales ( i have a lot of irf irfp IRF9240/240) but spencer shop is closed .
have you another source for pcb ?
thank's
fgaston
Old 1st April 2013, 11:01 AM   #1717
omishra is offline omishra  India
I completed my dual mono vertical box. Running successfully at source resistor voltage drop 300mV(0.6A bias) per device. Thanks again NP, all FM here and buzzforb for semiconductors.
Power Supply, mains section. I used softstart and thermal cutoff from bay.
Closeup each toroidal transformer is 300VA, 2X24V secondary.
Partition separation - 7mm gap between open end of transformer mounting bolt and side panel. 5-6mm gap for power caps and side panel.
Other side of the partition, all power bank of DC voltages. I used 8 X 15000F per channel.
Closeup of power switch and reset switch for slow start. My amp does not power on automatically on mains supply reconnection. It needs push button trigger to switch on.
Both 75C thermostat attached to heatsink using spring taken out from cloth drying clip.
Closeup of mains earth ground isolator. Bridge connects mains ground to chassis at central mounting bolt and PS AGND comes from behind PCB at bottom.
Aluminum handles fitted with M4 SS bolts. Indicator 3mm red LED into hole with 2mm opening in top and 3mm from behind on face plate. LED hole filled with transparent hard glue.
Side view of complete box.
Old 1st April 2013, 12:14 PM   #1718
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
that's Fugly!
mount lower and bottom plates (regularly looking as front and back ) via some spacers - to ensure some vertical air flow inside the case
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 1st April 2013, 12:17 PM   #1719
Originally Posted by Zen Mod View Post
that's Fugly!
Thanks ZM! Yes there is some gap (~3mm) between top and bottom plate along with side panels.
Old 1st April 2013, 12:18 PM   #1720
Rixsta is offline Rixsta  United Kingdom
Source = 1-3v
Speakers = 87db
So just wondering if i need a Pre as well as B1.
But also its possible he could connect up a quieter device, perhaps having that niam clone pre-amp would be good idea anyway.
www.rikibuckingham.com... DIY=Zen V4, Zen-lightenment‎, Jean Hiraga 20w,
ACA, F5, F5T, Audio Freaks Club
F5 Turbo Builders ThreadHide this!Advertise here!
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 07:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 08:14 PM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
