F5 Turbo Builders Thread
Old 20th March 2013, 07:23 PM   #1661
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
that said, I think the original BA-1/2 idea by Nelson kind of opened the door to using two heatsink per mono amp
negative and positive side on each their seperate heatsink
or at least it looked that way to me
DC drift problems ? ....dont know
Old 20th March 2013, 07:24 PM   #1662
AudioSan is offline AudioSan  Norway
Originally Posted by tinitus View Post
maybe also focus on good venting of the box itself
it would be possible to make it work in unity with heatsink convection
difficult with a standard box design
but might work well if lifting the lid up using print board stands
imo...not sure I would like to mess with anything that wouldnt work with 'normal' heatsinking....whatever normal is
i'm going to use 10mm PCB spacers between the sinks on top lid
well. normal heatsinking? it's no such thing in class A world
Old 20th March 2013, 07:27 PM   #1663
thats what i'm going for on my v3 mono's.
Old 20th March 2013, 10:18 PM   #1664
Rixsta is offline Rixsta  United Kingdom
those who built the F5T what was your main reason ?
Did you realy feel like the 25w version was not enough ? and why ?
www.rikibuckingham.com...
Old 20th March 2013, 10:29 PM   #1665
just to try it. and that i allready had a lot of parts for it. like transformers, caps, heatsinks+++
Old 20th March 2013, 11:59 PM   #1666
Thanks, yeah ive got a few transformers lying around that i probably wont need, one or two for the Zen4.
So just to sum up, for F5T (v2)
those of us using modushop.biz chassis, we need atleast the 5U - 400mm ?
That sounds good, maybe a kind of wire see thru mesh would be good for the lid, i always like to see inside lol and make it pretty with LED's inside haha
Old 21st March 2013, 01:19 AM   #1667
Marching on have found my next issue, the non-existant output transistors FQA12P20, FQA19N20.
Best alternative for F5Tv2 ? are the Irf/irfp pair usable ? they are quite expensive too, i guess any transistor like this is.
Old 21st March 2013, 01:31 AM   #1668
i would go for 5U 500mm.
the irfp part are easy to come by, and cheap. the also work great.
Old 21st March 2013, 02:36 AM   #1669
BigE is offline BigE  Canada
BigE's Avatar
Originally Posted by Blink_PT View Post
I made this simple circuit on startup, is simple and works great.
That circuit is for the primary side/transformer startup only. It also has a VA rating limit.
Old 21st March 2013, 12:04 PM   #1670
you can get the sj74/sk170 pairs from some members here. Spencer among others.
rest of the parts you can get from mouser, if you og for irfp240/9240 outputs. but remember. they will need matching. you can also get those fets matched from another member here, h_a.
you mean that like the IRF mosfets need matching but some of the othrers don't ?
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
