F5 Turbo Builders Thread - Page 145 - diyAudio
Old 23rd February 2013, 05:03 PM   #1441
coils is offline coils  United States
Originally Posted by zoe View Post
Green wire connects amplifier boards grounds together
That is creating a loop, I would cut that one out.
Coiler
Old 23rd February 2013, 05:06 PM   #1442
Originally Posted by Blink_PT View Post
I wonder if any member has connected two independent secondary with one bridge.
Bkink, I just noticed that the burning amp 1 psu is wired that way, as 6L6 said it is common.
Coiler
Old 23rd February 2013, 05:10 PM   #1443
6L6 is offline 6L6  United States
6L6's Avatar
I think it's probably a better idea to use dual rectifier bridges with a dual secondary transformer. However, the single bridge does work, and has been used in many successful commercial and DIY projects.
I think Nelson usedit in the F5T article mainly to utilize the MUR3020 diodes.
This is a time when there is more than one correct answer to the question. Remember that we need +32v/GND/-32v clean, quiet, and of sufficient current to keep the amp happy. There are lots of ways to do that.
Old 23rd February 2013, 05:18 PM   #1444
6L6's Avatar
Question - Has anybody had a successful build of a V2 or V3 using the seperate toecutter Front-end board and output boards?
I know there are a few all-in-one boards out there, I'm interested in the 3-peice (or more) boards.
Old 23rd February 2013, 05:51 PM   #1445
zoe is offline zoe  United States
I have a single bridge with two transformers tied together I am trying different things to learn. I started with single transformer single bridge.Now that I received more diodes I'll build one more bridge. One for each transformer Later separate capasitor banks I still have a small buzz only heard on quiet passages of music however I am spoiled as my F5 is dead quiet. I have had noisy risitors in the past as you can see from pictures I am using rather inexpensive ones.I will also try removing transformers from the chassis and running long wires to ps probaly next week as it's a beautiful day I'm going to take a hike.
be good
zoe
Old 23rd February 2013, 08:55 PM   #1446
Marra is offline Marra  United Kingdom
My amp section is wired and biased;just the power supply box to make when the aluminium finally arrives.
I really must get my eyes tested.
Old 23rd February 2013, 09:48 PM   #1447
noSmoking's Avatar
hi looking good!
Back off about 6 " and then crop the pic it will be in focus then,not so fuzzie,I like the add on heatsink Idea!Good work!
NS
Old 24th February 2013, 03:29 AM   #1448
hello. i have a successful power up of this boards. well. i have only fired up the front ends yet. with cascoding.
Old 24th February 2013, 01:49 PM   #1449
6L6
Would you like me to send you a set to play with?
Old 24th February 2013, 06:05 PM   #1450
They will make changing out the cooked mosfets easier! Have you figured out what keeps zapping them? I'm wondering if I should pay for some extra sets...
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
