Old 21st February 2013, 06:46 PM   #1411
Blink_PT's Avatar
Originally Posted by ijscobar View Post
Transformer question... I'm planning to buy transformers from Toroidy. They offered me a price for a normal transformer and an audio grade transformer.
This is what they write about the audio grader transformer:
I used to buy normal transformers for my amps. Never had any complaints about them. So I was wondering if there is any benefit in using "audio-grade" transformers. Is it, soundwise, a big difference?
This image is a Toroidy, will come a week ago. It came without magnetic shielding because I asked (increased another 2-3 cm in diameter). It has a small mechanical noise by opening the lid of the box.
Comes with electrical protection, grounding wire, and the center with expoxi and mounting flanges.
You should ask with flexible connections, but comes standard with solid core wire.
Old 21st February 2013, 08:13 PM   #1412
WalterW is offline WalterW  Netherlands
Got a crazy idea, would two of these boards with 100 x 1000uF be nice to use in my F5T v1?
Will it give a better sound or performance instead of picking 4 big, say 47.000 uF capacitors?
Old 21st February 2013, 08:17 PM   #1413
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
probably yes
under condition that these 100 aren't drek
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 21st February 2013, 10:26 PM   #1414
Renron is offline Renron  United States
Renron's Avatar
Drek?
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 21st February 2013, 10:36 PM   #1415
6L6 is offline 6L6  United States
6L6's Avatar
Not good quality, operational but barely, poor, bad, cheap, junk, etc...
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 22nd February 2013, 02:58 AM   #1416
zoe is offline zoe  United States
I also have grounding issue, small buzz. I tried Zen Mod's tricks. Now buzz is in left speaker only. Amplifier sounds better then expected . Zen Mod do you have any more tricks? Buzz as you said fet still works. I broke fet while drilling to enlarge hole for screw.
be good
zoe
Old 22nd February 2013, 03:00 AM   #1417
be good
zoe
Old 22nd February 2013, 03:20 AM   #1418
Rush is offline Rush  United States
Originally Posted by zoe View Post
I would use some high temperature epoxy and glue the pieces back in place, if it does still work.
B Weld 8265S Weld Compound - Epoxy Twin Pack : Amazon.com : Automotive
Rush
Old 22nd February 2013, 03:34 AM   #1419
Glued with epoxy steel J B Weld before installation. Seemed to work well. I hope I can get the screw out later as I did not want to wait for the glue to dry .Greedy boy has no patience.
be good
zoe
Old 22nd February 2013, 03:52 AM   #1420
Should have waxed the screw first.
Rush
B1 builders thread Bas Horneman Pass Labs 690 Yesterday 11:59 AM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2143 18th June 2013 07:18 PM
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
