F5 Turbo Builders Thread - Page 137 - diyAudio
Old 18th February 2013, 05:53 PM   #1361
sts9fan is offline sts9fan  United States
Nice suggestions.
Can you explain the implementation on the 5A switches?
Old 19th February 2013, 07:10 AM   #1362
noSmoking's Avatar
Those look very Professional,I wish I had that midas touch!
Old 19th February 2013, 07:36 AM   #1363
noSmoking's Avatar
Originally Posted by nrg2009 View Post
NS, maybe post a photo of your VU meter. I'd like to add some visuals if they are cool and not too complex.
Hi Nrg2009,
I didn't forget about the plasma vu meters see the pics ,just been busy built 2 Salas Riaa and the shunt supplies for Riaa for my old turntable ( had nothing to plug it into) and also built 2 Salas DCB1's board for a preamp, I will run them Balanced,My F5'ss are water cooled,I am doing a layout for the cabinets to put them all in,Lol,got to have fun,lol
Happy Listening!
NS
Old 19th February 2013, 10:57 AM   #1364
buzzforb's Avatar
NoSmoking,
If that is the folded, you are going to like it very much. Be forewarned, it is good enough that it dissapears and is largely defined by the cap at the output. Rush coupled the secondstage to a DCB1, dropping the buffer, and was able to use high quality .1uf cap vs 2+uF recommended for the standard layout. Luckily i was feeding high Zin tube and was able to use a SIO. I wi ll be trying K75 bypassed by teflon next.
...Shape the sound , Man!
Old 19th February 2013, 04:18 PM   #1365
SRMcGee is offline SRMcGee  United States
SRMcGee's Avatar
Originally Posted by sts9fan View Post
Anyone have some "cool" power switch suggestions for the front panel of a V2?
Push button round would be nice. I have been looking at Digikey but not really found anything.
Folks:
I was wondering about finding large (25mm) illuminated anti-vandal switches myself; I have a preference for blue ring variants and found the following: http://www.langir.com/46FC2DAD-28AF-...ant-switch.pdf
These are rated at 250VAC/5A, which I assume would be suitable for an F5T V2 (120VAC and presumably less than 10A). My attempts at locating a commercial retailer of these switches was unsuccessful, but Langir apparently offers them directly at volumes of at least 20 units. Is there enough interest to justify a group buy?
Scott
Good decisions are derived from experience; experience is derived from bad decisions.
Old 19th February 2013, 04:34 PM   #1366
noSmoking's Avatar
Hi Buzzford,
Thanks for all the info I'll give it a try and see how it sounds!
NS
Old 19th February 2013, 06:00 PM   #1367
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
@ noSmoking. care too tell/show more of your water cooling rig??
" If you're going throu hell, keep going"
Old 19th February 2013, 07:23 PM   #1368
WalterW is offline WalterW  Netherlands
The extra heatsinks arrived today...( see pictures) pfff.. that's a whole new ballgame...
Construction of the case and lay-out inside the case must be reconsidered with this much of height...
And that for "only" 50 Watts of class A into 4 Ohms
Old 19th February 2013, 08:44 PM   #1369
henryve is offline henryve  South Africa
henryve's Avatar
Good heatsinks! Looks like Fischer SK157 profiles.
Old 19th February 2013, 09:40 PM   #1370
Where did you order the heatsinks from?
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2389 9th June 2016 10:07 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
