F5 Turbo Builders Thread - Page 134 - diyAudio
Old 14th February 2013, 01:24 AM   #1331
buzzforb's Avatar
Originally Posted by AudioSan View Post
alu is a devil to work with. it can bite ur ars off.
Ring finger. In this case If I could get it to bite **** off regularly, I would make a fortune selling services to women looking to downsize
...Shape the sound , Man!
Old 14th February 2013, 01:29 AM   #1332
thats an idea
well. all aloy's is a bitch. they need some special care regarding tools.
Old 14th February 2013, 01:44 AM   #1333
zoe is offline zoe  United States
can I use these to insulate my mosfets
they have a hole Hole will fill with grease no?
be good
zoe
Old 14th February 2013, 01:59 AM   #1334
i will not recomend that. use insulators that is ment for your type of mosfets. those can send a spark to the heatsinks. and thats something you don't want
take a look here after the 15th. : Assorted Components Kit, Modules items in Electronics-Salon store on eBay!
Old 14th February 2013, 02:41 AM   #1335
Lo_Tse is offline Lo_Tse  Canada
Audiosan
Do you mean there are too many holes on the insulator or mica is not a good insulator? I have bought a bunch of those expensive keratherm red pads for TO-267 (I think) BJT. I hope they will fit the mosfets used in the F5T.
Old 14th February 2013, 02:49 AM   #1336
i mean that there is too much holes. mica is fine as a material. TO-267 is a bigger chassis then TO-247. but thats no problem..
Old 14th February 2013, 05:02 AM   #1337
henryve is online now henryve  South Africa
henryve's Avatar
If you have some metalworking experience you can work to 0.2mm precision with a standard woodworking blade on the tablesaw and a set of files. You have to know how to handle a file. Most people don't. Also, when drilling, get a set of spotting drills. Most normal drills wander a bit when you start off the hole from a punched mark.
Old 14th February 2013, 05:11 AM   #1338
henryve's Avatar
Had a friend lose an eye using grinder on aluminum.
Never, ever use a grinder on aluminium. The aluminium blocks the little holes in the material of the blade, heats up and expands, eventually leading to the cracking of the blade.
I will eventually get a proper aluminium blade. It leads to less hard work with the file after the cut. I used candlewax for the lubrication of the blade. And yes, that bloody aluminium chips hurt when they are flinging all over the place.
Old 14th February 2013, 06:11 AM   #1339
bk856er is online now bk856er  United States
bk856er's Avatar
Slightly OT, but I need to learn more about working with aluminum. I thought a center punch, drop of cutting oil, sharp bit and proper rpm were the main things. Never could get the accuracy I wanted/expected. Spotting bit makes perfect sense - never knew such a thing existed. Below is a recent effort with a cordless hand drill (no spotting bit). It took a long time!
BK
Old 14th February 2013, 06:22 AM   #1340
that depends on the tools as much as the the one operating it.
0.2mm is 1/10 of the blade. dont you ever try to to convince someone that they can do that pressision without alot of cutting behind them. and a saw guide. even that might not be good enough.
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 04:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
