F5 Turbo Builders Thread
Old 10th February 2013, 11:36 AM   #1291
kroyin is offline kroyin  India
Option 1--8 irfp240 mosfets each being fed 1 A supplied by 16V rails
Option 2 -- 4 irfp150 mosfets each being fed 2 A supplied by 16V rails (ZM just squashed this :-))
I'll try both.
The funniest part is that i'm currently ravaging the AJ, one channel with 1 pair (1A each @ 24V), the other channel 2 pairs (1A each @ 24V), i hear no difference, guess my 8 ohm spk's are real 7~8 ohm (not current hungry) (or) my headphones have shorted :-) :-)
Lets just stay on F5T :-) :-)
Asus Netbook (ALSA+MPD)->EBay 4xWM8741 DAC->DIY DCB1 preamp with Optical Volume Control ->DIY F5T V2-> DIY 2.5 way Peerless Nomex by Troels Gravesen
Old 10th February 2013, 02:12 PM   #1292
a.wayne is offline a.wayne  United States
Sin Bin
Difficult to hear differences without a proper setup ...
Old 10th February 2013, 02:16 PM   #1293
Sin Bin
Originally Posted by kroyin View Post
Pics of my utilitarian F5 V2 monoblocks. Biased @ 320mV with ~8mV offset. Haven't had the chance to play with P3
Boards from indian group buy DIY: Pass F5 turbo v2 initiated - Page 18
Mosfet (perfectly matched) & diodes from Buzz
300VA, 8x15K caps per channel. Heatsinks are 500mm long with 125 mm width (not optimum config, but was cheap and handles the heat very well)
F5 vanilla didnt work for me, Aleph J set the bar pretty high, F5T V2 sailed over the bar (by a few centimeters :-)).
I would add another 300va transformer to maximize your output stage and for best sonics , a single 300va is way too small ..
Old 10th February 2013, 02:36 PM   #1294
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Here is retry of distortion measurement of my F5T. Slightly adjusted for higher 2k to 3k. THis gave the widest and best overall soundstage.
...Shape the sound , Man!
Old 10th February 2013, 02:43 PM   #1295
sachu888 is offline sachu888  India
sachu888's Avatar
I think he is using 2X300Va transformers.One 300VA/channel.
Sachin
Old 10th February 2013, 03:18 PM   #1296
dazed2 is offline dazed2  Canada
Buzz,
maybe a stupid question, but is the blue line 2nd order distortion? is there no 3rd order distortion at all? Or am I reading the graph completely wrong?
Old 10th February 2013, 03:26 PM   #1297
buzzforb's Avatar
THe blue line is the soundcard in loop back. Red is the amp. Look at the bottom of the graph for the frequency for the distortion. It was tested at 1k, so you see a spike there. Then 2k and 3k, falling in pretty good relation. Have a tiny bit of 5k, which i dont like, but unsure of how to get rid of it.
Old 11th February 2013, 02:08 AM   #1298
Lo_Tse is offline Lo_Tse  Canada
The peak at 2KHz is below -90 dB and the signal at 3KHz is below -100 db (there is a trace at 4Khz but it is below -120db). This is pretty good.
Old 11th February 2013, 02:31 AM   #1299
buzzforb's Avatar
Yes. I could drop the 2k alltogether and lower k3, butbi dont like the sound as much
Old 11th February 2013, 05:21 PM   #1300
Marra is offline Marra  United Kingdom
I fired up my F5T V2 this afternoon and one channel was adjustable as req'd but the other one would'nt go above .32V before the trimmer started clicking.I know I need to increase the value of R5/6 but wondered is there a resistor value to use and is it worth changing them on both boards?
Ignore this I found the answer in #971.Thanks Audiosan
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
