F5 Turbo Builders Thread - Page 125 - diyAudio
Old 3rd February 2013, 07:19 PM   #1241
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
And also I noticed that the heatsink within about one minute had room temperature!That was fast!
Old 3rd February 2013, 08:32 PM   #1242
buzzforb's Avatar
The 2sk1530 has lower Vgs for given current in comparisonto 2sj201. If youhad both pots set to 1.5V, you would have sythe sk1530 biased fairly high, while the 201 would just be just turning on. Takr a look at the datasheets for appx Vgs for a given current.
...Shape the sound , Man!
Old 3rd February 2013, 08:38 PM   #1243
Nikitas's Avatar
I had them both set at 3V like we had discussed.
Old 3rd February 2013, 08:40 PM   #1244
buzzforb's Avatar
Originally Posted by buzzforb View Post
THey will work great and will plug directly in with little effect. Just look up their datasheet and try to get an idea of the VGs needed for the bias you want. Before plugging them in, set your pots below that point about 25%-50%. You have tested you FE and all is good. As long as you mount and isolate them correctly, you should be able to listen within the day.
Old 3rd February 2013, 09:24 PM   #1245
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
Odysseas - goal is to set them at desired current - measuring voltage across one of source resistors ;
that voltage is information about current flowing through resistor and mosfet itself
who cares what's Ugs ......
there are few tutorials floating around , and reading them few times is worthwhile
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 3rd February 2013, 09:43 PM   #1246
Nikitas's Avatar
Yes, thanks ZM, looking at the differences at the datasheets of the two toshibas, I wonder what would that (desired) current is. I just want to be at all times class A.
There is quite some difference at the current drain at the same voltage, like buzz pointed out.
Old 3rd February 2013, 09:51 PM   #1247
buzzforb's Avatar
Shoot for 300mV to 400mV across the Rs. Start at 300 and let it warm up.
Old 3rd February 2013, 10:19 PM   #1248
Zen Mod's Avatar
do what buzz buzzed few times to you , already ;
stay in ballpark for your project (didn't read which iteration you are exactly building) keeping in mind that (say) 40W per device and 55C at heatsink are limits which you must respect
Old 4th February 2013, 01:47 AM   #1249
buzzforb's Avatar
THis is probably done wrong, but i think this is my 1W performance
Old 4th February 2013, 02:05 AM   #1250
6L6 is offline 6L6  United States
6L6's Avatar
Awesome!
How do you read that graph... ?
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2389 9th June 2016 10:07 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
