F5 Turbo Builders Thread - Page 122 - diyAudio
Old 1st February 2013, 06:51 AM   #1211
buzzforb's Avatar
Any dc on the output of the preamp will change bias point of input Jfets, as they will see it as an additional voltage on their gate, and bias is ultimately determined by Vgs.. Add cap on outputof b1 or input of f5t and see what happens.
Old 1st February 2013, 06:56 AM   #1212
kroyin is offline kroyin  India
Thanks Buzz, but as i said with the preamp off (no DC) it still gives me -80mV.
I think that this is related to grounding in F5T (used the grounding scheme as suggested in F5T article-- that is using a 4 prong chassis mount diode and CL60). I must have done something wrong. I'll try the old scheme (no diode just the CL-60 in between the PSU ground and chassis ground) in the other channel.
But then again for the sake of testing, i connected the alpeh-j input (switched off) with F5T input (switched on) get 8mV F5T offset.
Connected DBC1 output (switched off) with F5T input (switched on) get -80mV F5T offset. This points that the F5T grounding is ok
Why cant i have easier issues (like mosfets blowing) :-D
Old 1st February 2013, 07:07 AM   #1213
buzzforb's Avatar
I don't know. When setting bias, do you short the input? Is the amp oscillating?
...Shape the sound , Man!
Old 1st February 2013, 08:26 AM   #1214
Well i clip the AGND & IN wires with a alligator clip while biasing.
Cant tell about oscillation (no scope) but there is no unnecessary heating
Old 1st February 2013, 10:07 AM   #1215
buzzforb's Avatar
Don't know. Something is changing DC condition slightly. Double check all joints on connectors and inputs. See If you DMMnset on AC picks anything up when it is hooked up to the pre.
Old 1st February 2013, 10:52 AM   #1216
Originally Posted by AndrewT View Post
why do you need to be told again and yet still insist it is right?
You have mixed up Vac V rms, Vpk and Vpp
Should I need to repeat what I posted?
BigE could see it
1) 29 V P-P should just read 29V peak.
But AudioS is so full of himself, he could not be bothered to actually read what he had typed and take on board the advice re confusion of voltage terms/units.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st February 2013, 10:45 PM   #1217
anilva is offline anilva  India
Is there any audible hum at the speakers. If there is no hum and just 80mv offset, one should not worry. I hope you adjusted the bias and offset after reaching full temperature on the heatsinks.
DIY F5, F5T, F6, Aleph J, Fostex 206 based BLH, Altec Onken with 515 LF & 288 HF, Technics SP10 MKII & EMT950 turntables
Old 2nd February 2013, 06:14 AM   #1218
that is much normal there is no input caps on the F5 to take care of the remaining ofsett. the alephs have this.
10times ofsett jump is normal. on the other hand. 80mV is not anything to loose any sleep over.
I completed 1 monoblock of the V2 turbo.
Bias (with output open, input shorted) is 360 mV and 8 mV offset.
I have one observation though
--When i plug in the DCB1 preamp (-1.2 mV offset), even with the preamp off i get a offset of -80mV from F5T. Goes back to 8mV when i unplug the input.
My Aleph J does'nt do that , with or without the preamp connected it gives me 25 mV offset.
Old 2nd February 2013, 06:22 AM   #1219
andrew. i hope you dont wright to me. then you are waising your time. you are on my ignore list now.
Old 2nd February 2013, 06:50 AM   #1220
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
BigE could see it
Hello Andrew.
could you please specify what is wrong. I don't see it
then again... I'm only here to learn so.......
set up the right formula for us, would you?
thanks
" If you're going throu hell, keep going"
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 08:26 AM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2389 9th June 2016 10:07 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 12:05 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 09:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 03:24 AM
Copyright ©1999-2017 diyAudio
