Old 28th January 2013, 09:52 PM   #1181
Renron is offline Renron  United States
Renron's Avatar
"wallet heat mass and weight for starter "
Seems unreasonable . Unobtainium!
100W Class A? sounds good to me!
3.6A ? It's gonna get hot. May have to add a small fan. Or change the subwoofer to a TRW-17
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 28th January 2013, 09:54 PM   #1182
Renron's Avatar
Buzz, have you finished your 4 pair / channel yet?
Old 28th January 2013, 09:54 PM   #1183
Originally Posted by buzzforb View Post
AudioSan,
You know that your about to have a lot of builders coming on line. Sure hope you got some extra time
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 28th January 2013, 09:56 PM   #1184
well. 3.6A will run cooler then 5.52A
build in some fans in the rack that blows air up thrue the sinks
Vivaldi8 speakers
Old 28th January 2013, 09:57 PM   #1185
buzzforb's Avatar
AudioSan said he was goign to finish first. I am waiting on him.
Truthfully, THe F5T is a COMPLETELY different sound than the F5, which I did not prefer. If the V3 version improves things as much as the V2, I might quit.
Ignore that. IT was said in moment of insanity. I am in fact not doing a V3, but instead a balanced V3, with a twist
Or chimney.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 28th January 2013, 10:06 PM   #1186
at least a got the M3 tap now so i'm only waiting on som alu. i think i finnish the chassis before i power it up. if i don't, it will never be finnished
a chimney will give a lot more mechanic noise. but demands less fans.
Vivaldi8 speakers
Old 28th January 2013, 10:43 PM   #1187
a.wayne is offline a.wayne  United States
a.wayne's Avatar
well. i can think of a copple of things. wallet heat mass and weight for starter
and to acctualy get 480W output you need some high voltage. about +/-90V.
2*90V*5.52A=994W dissipation pr ch at idle. and this is minimum
if you want to get say 100W class A at 4ohm, you need about 3.6A bias. and around +/-32V rails(fully loaded)
San,
Can you explain how you are calculating the power from 32v rails ...?
A man should look for what is, and not for what he thinks should be. -Albert Einstein
Old 28th January 2013, 11:17 PM   #1188
Originally Posted by a.wayne View Post
San,
+/-32V rails give you about 29V P-P on the output.
29*29/4ohm=210W peak or 105W Rms.
for class A power:
3.6A*2=7.2A peak.
7.2*7.2*4ohm=207W peak or 103W Rms.
Vivaldi8 speakers
Old 29th January 2013, 01:19 AM   #1189
a.wayne's Avatar
OK .....
Old 29th January 2013, 05:48 AM   #1190
Renron's Avatar
Thank you very much AudioSan. That was very enlightening.
I look forward to your impression of the 4 pair version.
Ron
F5 Turbo Circuit Boards chchyong89 Pass Labs 2131 23rd May 2013 10:36 PM
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
B1 builders thread Bas Horneman Pass Labs 688 27th February 2013 11:15 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2013 diyAudio
