F5 Turbo Builders Thread
Old 28th January 2013, 07:33 PM   #1171
a.wayne is offline a.wayne  United States
Sin Bin
You should try one, much better than the little wimp's you adore ...
Old 28th January 2013, 07:45 PM   #1172
AudioSan is online now AudioSan  Norway
well. i'm not running 2-3ohm speakers
Old 28th January 2013, 07:51 PM   #1173
Sin Bin
neither am I ...
You would be surprised at how much of a difference it makes , regardless of your speakers, a big un , tends to do big very well , look at NP, production amplifiers for guidance, everyone i have ever owned or saw had more outputs than sand ...
Old 28th January 2013, 08:11 PM   #1174
lots of outputs. yes. but no one have that amount of bias VS rail voltage
5.52A bias makes it good for over 480W class A power at 8ohm. but it is voltage limited at around 50W at 8ohm with +/-32V rails.
Old 28th January 2013, 08:16 PM   #1175
buzzforb is offline buzzforb  United States
buzzforb's Avatar
Originally Posted by a.wayne View Post
neither am I ...
I agrre with Wayne on this one. Unless you got old school, lighteight, HE drivers, the extra grunt makes a difference. Example. JBL 2226H (600W motor)vs Altec 515(200W motor). Similar specs(not VAS or cone weight), but very different results from same power level.
Originally Posted by Zen Mod View Post
speaking of that (and being in jeopardy of going off topic ) it's always confusingly amusing , when ppl are amusingly confusing efficiency ..... and sensitivity ;
not speaking about you and your setup , even if you were in few steps close to making same mistake .... just differentiate power needs when using old school 96db/W/m driver vs. modern 96db/W/m driver
old one is having 60W capacity vs. new one having 250W capacity
much lighter and agile moving ansamble vs. not so light and not so agile .....
yukyuk
edit: luckily - there are still few mnfctrrs , making new old school drivers
...Shape the sound , Man!
Old 28th January 2013, 08:24 PM   #1176
well. also here it is a matter of taste and money
Old 28th January 2013, 08:40 PM   #1177
buzzforb's Avatar
Nuh uh.
Old 28th January 2013, 09:09 PM   #1178
Renron is offline Renron  United States
Renron's Avatar
And what's wrong with <480W Class A power???
LOL, I was just finishing the equation from ZM. Someday I may understand what he says. I never said I was going to build it!
I'm just trying to figure out what I want to build when I get some boards and Antek re-opens. I don't know squat and freely admit it. Just dreaming perhaps, but a F5T w/o diodes just might be the ticket to drive Seas Thors. 4Ohm
Not interested in SPL so much as low-mid volume grunt.
Glad to entertain ideas.
Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 28th January 2013, 09:32 PM   #1179
well. i can think of a copple of things. wallet heat mass and weight for starter
and to acctualy get 480W output you need some high voltage. about +/-90V.
2*90V*5.52A=994W dissipation pr ch at idle. and this is minimum
if you want to get say 100W class A at 4ohm, you need about 3.6A bias. and around +/-32V rails(fully loaded)
Old 28th January 2013, 09:50 PM   #1180
buzzforb's Avatar
AudioSan,
You know that your about to have a lot of builders coming on line. Sure hope you got some extra time
F5 Turbo Builders ThreadHide this!Advertise here!
B1 builders thread Bas Horneman Pass Labs 728 12th March 2018 06:45 PM
F5 Turbo is posted Nelson Pass Pass Labs 638 27th December 2017 06:12 PM
F5 Turbo Circuit Boards chchyong89 Pass Labs 2404 8th October 2017 07:14 PM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
