F5 Turbo Builders Thread - Page 109 - diyAudio
Old 16th January 2013, 06:08 PM   #1081
oiphy is offline oiphy  Norway
diy newbie
oiphy's Avatar
Originally Posted by buzzforb View Post
I enlarge my fet holes, as an M3 tap is impractical IMO.
is this possible got an old amp(cayin 270p) with problems regarding bad treads. fets are under the board so clamping's not possible
edit: could I take a 5mm drillbit and drill the hole bigger ??
" If you're going throu hell, keep going"
Old 16th January 2013, 06:22 PM   #1082
buzzforb's Avatar
Yes. I do it with every amp. A standard fet will not except a 6-32 screw as it is slightly bigger than M3. Luckily M3 holes can be easily enlarged using just the 6-32 screw. Just use vise grip pliers to hold fet and go to town on that bad boy. Often though, I kick it up to 8-32 so i can use larger, tougher tap.In this case, I will use a bit to enlarge the hole.
If worried, just practice on cheap, extra fets. i think you can take an M3 to M4 with out too much trouble. Just retap hole
...Shape the sound , Man!
Old 18th January 2013, 08:28 PM   #1083
Hi All,
May I ask for a little advice? I thought I should build the power supply part of the F5 first then the audio. However I turned it on for the first time and it blew the small 1.25A fuse immediately, however the large bank of PSU caps still where giving out about 5v dv after 30 seconds. The fuse in the plug is still fine.
I have been over the wiring twice now and can't see any mistakes. I should say that I went for the more powerful transformer to enable me to get 50W output. What do you think I should try to fix my issue?
Old 18th January 2013, 09:01 PM   #1084
buzzforb's Avatar
Draw how you wired it. It will cause you to go back over it as well as give us something to go by.
Old 18th January 2013, 09:16 PM   #1085
Blink_PT's Avatar
Originally Posted by SteveHolt View Post
Hi All,
It is not clear images, place a scheme.
If all is well, increase the fuse to 2A, and do not forget the link CLC-60 in primary toroidal.
Old 18th January 2013, 11:16 PM   #1086
Hi Guy's thanks for a quick response.
I have attached the schematic from firstwatt.com and a close up photo of my transformer
I have used the 240 V diagram as I live in the UK.
I have connected the blue and white together with the thermistor, this could be a mistake as they are shown as a pair on the transformer label, have I made a mistake?
Is my second mistake that I wired up the earth from the mains power to the chassis when I should only have connected it to the CL60 thermistor?
I will also try a 2A fuse next time
Old 18th January 2013, 11:32 PM   #1087
buzzforb's Avatar
I had my v2 running on 1A slow blow for months. The reason I wanted you to draw and not post pics is that it might help you find an error. If you draw while checking, you might just draw you mistake. Maybe you spot it, maybe we do, but it gives us something to check.
Old 18th January 2013, 11:32 PM   #1088
anilva is offline anilva  India
It is a mistake. For 220V, connect white and violet of the transformer to the thermistor and the other two to the power line through switch and fuse.
DIY F5, F5T, F6, Aleph J, Fostex 206 based BLH, Altec Onken with 515 LF & 288 HF, Technics SP10 MKII & EMT950 turntables
Old 18th January 2013, 11:35 PM   #1089
not sure but this schematic is for a standard F5.
The F5T is fed 32v after capacitor bank and should use a "beeefier supply".
If I recall, there was a rectifier bridge tied to ground.
See the schematic of the f5T power supply.
Old 19th January 2013, 12:09 AM   #1090
Blink_PT's Avatar
You have a toroidal 2X24V, is build an F5 Turbo V1 with a 300VA toroidal?
F5 Turbo Circuit Boards chchyong89 Pass Labs 2396 15th February 2017 03:10 AM
B1 builders thread Bas Horneman Pass Labs 722 16th November 2016 07:26 AM
F5 Turbo is posted Nelson Pass Pass Labs 636 13th January 2016 11:05 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2017 diyAudio
