Old 16th January 2013, 03:24 PM   #1071
buzzforb's Avatar
You can set bias post at about 3.5V and be safe to attach output fets. This will get you close to turn on voltage and allow less turning to achieve final bias. If you have FE boasting correctly, there is little you can do at this point to hurt the build. Before firing up check isolation of fets with MM set on Resistance setting, touch drain of get and sink at same time. It is the only thing left you could do wrong
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here
...Shape the sound , Man!
Old 16th January 2013, 03:29 PM   #1072
Marra is offline Marra  United Kingdom
Thanks Buzz.I've a way to go yet but pcb's are part populated and heatsinks drilled and tapped;I've just to decide on one or two chassis i.e seperate power supply casing.
Old 16th January 2013, 03:32 PM   #1073
PKI is offline PKI  United States
PKI's Avatar
Guys, is this a good sink for MUR3020W? 657-15ABP Wakefield | Mouser
Old 16th January 2013, 03:34 PM   #1074
a.wayne is offline a.wayne  United States
a.wayne's Avatar
Cmon Buzz ,
Time to finish your best one yet , the 4pr is calling ...
A man should look for what is, and not for what he thinks should be. -Albert Einstein
Old 16th January 2013, 04:06 PM   #1075
Renron is offline Renron  United States
Renron's Avatar
PKI,
I have those sinks on my regulator diodes. They work well. make sure the enclosure has vent holes for fresh cool air. Keep them electrically isolated, then you don't have to use silpads or mica or whatever......
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
"I fired up the prototype. Literally." The Prophet Pass.
Old 16th January 2013, 04:31 PM   #1076
buzzforb's Avatar
Originally Posted by a.wayne View Post
Cmon Buzz ,
AudioSan was suppose to take the heat off me. Gotta finish Salas SMD RIAA for brother this weekend. Guess i got to beat that damn F5TV3 bug after all.
Old 16th January 2013, 04:43 PM   #1077
hehe. i'm a little stuck at the moment damn that M3 tap. and alu.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC).
Vivaldi8 speakers
Old 16th January 2013, 05:18 PM   #1078
buzzforb's Avatar
I enlarge my fet holes, as an M3 tap is impractical IMO.
Old 16th January 2013, 05:25 PM   #1079
vel. M3 is practical over here
Vivaldi8 speakers
Old 16th January 2013, 06:06 PM   #1080
buzzforb's Avatar
Its not about availability, but size. I would go with m5. Take necessary bolt/screw, put in fet hole, use speed of hand drill to reem out.Got perfect size hole and stronger bolt/screw.
F5 Turbo Circuit Boards chchyong89 Pass Labs 2131 Yesterday 10:36 PM
F5 Turbo is posted Nelson Pass Pass Labs 589 1st March 2013 01:19 AM
B1 builders thread Bas Horneman Pass Labs 688 27th February 2013 11:15 AM
F5 turbo problems Rob Dingen Pass Labs 17 11th January 2013 08:38 PM
F5 Turbo ............. if only !!!!!! a.wayne Pass Labs 23 21st January 2012 02:24 AM
Copyright ©1999-2013 diyAudio
