#1061 |
i'm also building chassis my self. and for the turbo v3's. i'm looking at $500 in material. NOT inkl heatsinks. and NOT inkl CNC of logo. and after all that, i need to lay out a finnish.
aleph P1.7 pre. F5 power amp. CDpro2(need DAC). Vivaldi8 speakers |
#1062 |
That case that I made for the KSA50 worked out to about $500 in material, inclusive of the heatsinks. But then I must say Aluminium is cheap in SA compared to Europe. But I still need to cost in the CNC work for my front plate.
I will probably order my trafo from Amplimo or Toroidy and that is where you save again, since I have to factor in shipment. I am dissappointed with the quality of the 2 500VA trafos that a local company wound for me as used in the KSA50 clone. For the F5TV3 monoblocks I am looking at maybe a 1KVA trafo for each monoblock, and that will cost me an arm an a leg from either of those 2 suppliers. |
#1063 |
#1064 |
#1065 |
Yes you can never underestimate the cost and time involved in building the case.
The reason my original F5 took so long was that I built my own case. Borrowing time off a friends mini-cnc, tapping holes etc. took over 2 months! This time, I plan to have Antek / Par Metal build it for me They even have the heatsinks to boot! As for trafo, given the size of 1kVA anywhere of about $130 - $200US isn't bad. No one said a F5T V3 is cheap
#1066 |
Check out Antek Transformers. 1kv @35V x4 is $100 USD + shipping.
Antek - AN-10435 I've used one of their TX in my F5 for years and it NEVER gets hot or buzzes. No affiliation to Antek. Ron
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3 "I fired up the prototype. Literally." The Prophet Pass. |
#1067 |
Any news on the store F5T pcb's?
#1068 |
Buzz,
Any news on ToeCutters?
#1069 |
I know beta testers have them and from what I understand, all is OK. THey may be working out specifics and BOM. The store has them, just havent released them officially.
|F6 Kit/Trasnformer GB Sign up sheet Closed,|Primrose GB Sign Up sheetClick Here ...Shape the sound , Man! |
#1070 |
After doing the above do you set the trimmers back to zero?
| F5 Turbo Circuit Boards | chchyong89 | Pass Labs | 2131 | Yesterday 10:36 PM |
| F5 Turbo is posted | Nelson Pass | Pass Labs | 589 | 1st March 2013 01:19 AM |
| B1 builders thread | Bas Horneman | Pass Labs | 688 | 27th February 2013 11:15 AM |
| F5 turbo problems | Rob Dingen | Pass Labs | 17 | 11th January 2013 08:38 PM |
| F5 Turbo ............. if only !!!!!! | a.wayne | Pass Labs | 23 | 21st January 2012 02:24 AM |
